reprofile request
adamwalker
Fixes: 221
Re: reprofile request
OK, I'm surprised about the synch speed as line tests are showing me the line is synching at 9778, the line rate has been set to correctly reflect this at 8800kbps.
Just to clarify what you mean by "significant instability" are you referring to low/flucuating speeds or connection drops?
What does a test at http://speedtest.btwholesale.com/ over ethernet show you?
 Adam Walker
pinn
Connection drop outs resulting in pages not loading properly or at all, and downloads failing all the time.
Speed is reasonable but less than I received with Sky by about 200kb.
Results attached
adamwalker
Fixes: 221
Thanks, were you connected over WiFi or Ethernet?
 Adam Walker
pinn
That's via ethernet.
adamwalker
Fixes: 221
OK, it would be a good idea to report a fault over at http://faults.plus.net in that case.
Let us know when you have.
 Adam Walker
pinn
Hello,
line is now stable but speed has reduced significantly. Sync info below. Can you check I'm on the right profile, please?
Data rate: 1052 / 8981
7. Maximum data rate: 1068 / 9848
8. Noise margin: 5.6 / 7.7
9. Line attenuation: 23.3 / 41.8
10. Signal attenuation: 24.0 / 40.5
Fixes: 162
The router stats provide the SYNCH speed not (as incorrectly labelled here) the DATA speed.
That synch speed will deliver a profile of 7.9Mbps which ought to deliver a DATA speed around 7+Mbps.  What is the DATA speed test results you are seeing from an Ethernet connected device with nothing else happening on your network?
ejs
Aspiring Hero
Fixes: 25
Technically, the term "data rate" is more correct for that label, while "sync speed" is more of a slang term. Actual Net Data Rate is the proper term for what is usually referred to as the "sync speed".
Yes, the file download speed and speedtest results will be up to about 85% of the number shown by the modem.
Given the history of the thread, I think @pinn was referring to the DLM profile (target SNRM setting etc.) which only Plusnet can check.
Fixes: 162
Hi @ejs,
I smiled - as I wrote that I did wonder if you (if anyone) might add precision to the words I used, which are open to debate.  Terminology in this space is challenging - DATA speed tests are always going to be markedly slower that the line speed (by whatever name) and the (slang if you will) distinction between SYNC and DATA speeds is a useful distinction (and explanation) for the layman.
Besides which the perception of "DATA" is different depending on the context ... at raw communications level any capacity to move packets is "DATA" where as in common terms to ordinary folk "DATA" means the files they want to up or down load ... which is what DATA speed tests report ... and thereby deflate expectations.
I'd welcome a set of terminology which was technically more precise, yet still conveyed the important difference between what is being measured / reported in a way that does not confuse the average user.  In that context, given the common perception of what DATA speed means, I hold to the view that the use of "DATA" in relation to the speeds reported by the router can and will only lead to user confusion and unfulfilled expectations.
pinn
Abouut 8-900kb/s, previously was getting 1200kb/s
Fixes: 162
Having read the whole of the history here ... did you raise a fault report back in Jan 2017 and what happened?
For a 40dB attenuated line the speeds reported by the router are right on the nail and a BT speed test should deliver around 7Mbps.
Broadband is not going to work well if the "phone" line is not working properly.
Please perform a quiet line test - dial 17070 select option 2 using a corded phone plugged into the test socket behind the face plate of the master socket. It should be silent. A noisy phone line (or no dial tone) will have a marked adverse impact on the performance of broadband.
If the line is noisy or there is no dial tone, then a PHONE LINE fault needs to be raised with your phone provider. If this is PlusNet, you can report a fault on line using the button below.
What are the expectations for your line?
Please use the following links to check the services available and their estimated speeds. From the first link, please record and report back the distance from the exchange. The second link advises of which fibre services (if any) are available on your line and their anticipated speed.
How is your line performing?
Please post your router stats; for PN TG582n and 2704n routers use the buttons below, for other routers look at the Kitz link.
Also run a BT Wholesale speed test (ideally using an Ethernet wired PC with the WiFi turned off) then run the further diagnostics and post the results here. DO NOT REBOOT the router!
Also find your CURRENT SPEED (PlusNet line profile) from the PlusNet user portal - you will need to log in.
pinn
Thanks for the comprehensive respine.
NO fault was reported as my line returned to expected speed.
Don't have a corded phone so cannot check but line is quiet on wireless phone.
1st kitz link is as follows, although seems conservative:
Fixed ADSL:  4500 kbps (4.5 Mb)
DSL Max:   4500 kbps (4.5 Mb)
ADSL 2+ : 6000 kbps (6 Mb)
Second is as follows:
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 6 -- 3.5 to 8.5 Available -- -- -- --
WBC ADSL 2+ Annex M Up to 6 Up to 1 3.5 to 8.5 Available -- -- -- --
ADSL Max Up to 4.5 -- 3 to 7.5 Available -- -- -- --
WBC Fixed Rate 2 -- -- Available -- -- -- --
Other Offerings
Availability Date
ADSL Multicast -- -- -- Available -- -- -- --
Premise environment
Status
Bridge Tap U
VRI N
NTEFaceplate N
Last Test Date 18-01-1970
Router stats
1. Product name: BT Home Hub
2. Serial number: [removed]
3. Firmware version: Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated 14/07/17
4. Board version: BT Hub 5A
5. DSL uptime: 1 days, 16:37:17
6. Data rate: 1035 / 8312
7. Maximum data rate: 1036 / 9664
8. Noise margin: 7.0 / 9.4
9. Line attenuation: 23.4 / 41.9
10. Signal attenuation: 23.7 / 40.8
11. Data sent/received: 8.7 GB / 256.3 GB
12. Broadband username: [removed]
13. BT Wi-fi: No
14. 2.4 GHz Wireless network/SSID: BTHub5-2.4
15. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security: WPA2
17. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID: BTHub5-5
19. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security: WPA2
21. 5 GHz Wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: 00:37:b7:28:ce:94
24. VPI/VCI: 0 / 38
25. Modulation: G.992.5 Annex A
26. Latency type: Fast
27. Software variant: AA
28. Boot loader: 1.0.0
Plusnet reports speed as:
Estimated line speed:There's no speed estimate currently held on your account.Current line speed:7.3 Mb
Thanks in advance
Moderator's note by Dick (Strat): Personal information removed from a public forum.
Fixes: 162
That's a good collection of data.  The line is synching at 8+Mbps which is well over the estimate, but a bit shy of what the reported attenuation might give hope for.  The SNRM is a bit high - one needs to find the reason for that.
What does the BTw speed test report please?  The Plusnet profile (7.3Mbps) is right on the nail for the reported synch speed.  Thus far this all looks fine.
@CRT what is the target SNRM for this line please?
pinn
Missed that one; here we go
Fixes: 162
I believe that based on the information provided your line is performing near enough in line with expectations. If the line is very stable, a small amount more might be squeezed out if the DS Target SNRM can be changed to 3dB, but given your history I would leave it where it is.
