"slow" fttc
- Re: "slow" fttc
- « Previous
- 1
- 2
- Next »
Re: "slow" fttc
20-09-2012 4:30 PM
One more disconnect/reconnect should fix it! Sorry about the hassle.
Message 16 of 21
(341 Views)
Re: "slow" fttc
20-09-2012 4:38 PM
Message 17 of 21
(341 Views)
Re: "slow" fttc
20-09-2012 4:39 PM
that even better ! just wondering chris, what is causing it in the first place ?
Message 18 of 21
(342 Views)
Re: "slow" fttc
20-09-2012 4:42 PM
The line speed on our side was blank, this was incorrectly restricting down to 8Mb. James tweaked this but for some reason it didn't push through correctly so I fixed that and then made sure they were on the 77400 profile for their line.
Message 19 of 21
(342 Views)
Re: "slow" fttc
20-09-2012 4:45 PM
another thumb up from plusnet, they done the great job for you, but hey jackpr, you are lucky to have a brill fttc as I am still on ADSL2+ probably for the next 5 years! But glad for you.
Message 20 of 21
(342 Views)
Re: "slow" fttc
20-09-2012 4:53 PM
Indeed beer tokens for plusnet Not bad seeing as the cab is more than 3 streets away. Sure it wont be to long until you see the joys of fttc coming to you soon
Message 21 of 21
(342 Views)
- « Previous
- 1
- 2
- Next »
