painfully slow internet
- Re: painfully slow internet
- « Previous
- 1
- 2
- Next »
08-08-2009 11:20 AM
Dial 17070, listen to the automated response and select option 2 for the quiet line test then listen. If the line is quiet it passed. If there are crackles etc. then it is a voice fault and should be reported as such
Message 16 of 24
(403 Views)
08-08-2009 8:58 PM
hi again just did the line noise test now and i didnt hear any crackling or noises im pretty annoyed though because ive broken my extension cable to my loft which is where my xbox is dont suppose you know how to repair a snapped cable?
Message 17 of 24
(403 Views)
08-08-2009 9:02 PM
Not a clue I'm afraid - when mine failed I just had to replace it
Message 18 of 24
(403 Views)
08-08-2009 9:43 PM
Quote from: axlstod hi again just did the line noise test now and i didnt hear any crackling or noises im pretty annoyed though because ive broken my extension cable to my loft which is where my xbox is dont suppose you know how to repair a snapped cable?
What kind of cable?
Message 19 of 24
(403 Views)
08-08-2009 9:44 PM
would love to do that too but the route its got to go by causes a huge problem.lol.
Message 20 of 24
(403 Views)
08-08-2009 9:50 PM
its a extension cable ive broken the adapter part of it looking at it from the left its white/green white/blue white/orange orange blue then green the part thats broke off is yellow purple red orange blue and green,these were somehow attached to the others and have a black rubber to connect them together.
Message 21 of 24
(403 Views)
09-08-2009 1:10 AM
If I read that correctly, it's some kind of 6-core cable?
Sounds rather weird.
However, assuming its a telephone cable, ...
A few years back I wired in an extension telephone wire (about 15m) - however because the bit of wire I had wasn't long
enough, I soldered all the wires to their partner, wrapped insulating tape round each core and also the whole thing.
This was sufficient to be able to run 2Mbps fixed rate broadband.
I'm sure it would work for a voice line - and possibly for very slow internet.
Have you considered wireless?
Message 22 of 24
(403 Views)
09-08-2009 3:04 PM
If it is an RJ45 cable then this may help http://www.ertyu.org/steven_nikkel/ethernetcables.html http://www.alatec.com/info/rj45.html
You could of course just strip back the insulation and solder the correct wires to each other then wrap with insulation tape
Message 23 of 24
(403 Views)
09-08-2009 7:36 PM
If you have not done it before, crimping tools are very tricky (and not cheap) for the first few crimps
Message 24 of 24
(403 Views)
- « Previous
- 1
- 2
- Next »
