new router
- Re: new router
new router
22-01-2012 1:58 PM
i have just installed a new netgear n300 wireless gigabit modem router as i was having trouble with speed but now it is spot on, my question is i have been told it is best to leave the router switched on all of the time is this really necessary
thanks john
thanks john
Message 1 of 5
(6,425 Views)
4 REPLIES 4
Re: new router
22-01-2012 3:21 PM
It is recommended that you leave it on all the time if you want to achieve the best possible results.
If your line is near perfect, and is near the fastest that can be achieved then switching off is less of an issue.
If it is concern about electricity usage, modern routers are extremely low power consumption and will be barely measurable compared to say a freezer, when left on 24/7.
Message 2 of 5
(447 Views)
Re: new router
22-01-2012 3:23 PM
Not sure there is a definitive answer to this, or even a broad consensus of opinion, and it partly depends on how often you switch it off, and also when you switch it back on again and reconnect (re-synching at peak times and/or when noise levels are high can affect your sync rate.)
I would (cautiously! ::)) suggest that disconnecting the session via the router's interface and then powering down once a day does not usually cause problems.
Message 3 of 5
(447 Views)
Re: new router
22-01-2012 3:29 PM
Further to my comments above, on my own router I have installed an uninterruptable power supply to ensure my router NEVER switches off during mains power glitches, and will only go off if mains has failed for more than an hour or so.
As you can see from the speedtest below, I now get the full line profile of 7150Kbps on my 8meg line.
Message 4 of 5
(447 Views)
Re: new router
23-01-2012 10:49 AM
Hi jonco60,
We'd always suggest leaving it on all the time. However if you did just turn it off once overnight that shouldn't cause an issue on a stable line.
Jojo
Jojo
Message 5 of 5
(447 Views)
