netgear wireless router dg 834g
- Re: netgear wireless router dg 834g
17-12-2011 11:01 AM
17-12-2011 11:22 AM
17-12-2011 11:27 AM
17-12-2011 11:40 AM
Quote from: suef1965 i bought it second hand from ebay
Does it have a Netgear logo on the front or is it something else like Sky, for example?
Are you able to logon to the router at 192.168.0.1?
17-12-2011 11:55 AM
Quote from: MrT Are you able to logon to the router at 192.168.0.1?
[/quote
If it is Netgear, the router url is 192.168.0.1 and the default password is: password.
Chandu.
17-12-2011 12:07 PM
17-12-2011 12:11 PM
(doing this ensures that you get a new IP address via DHCP - the PN router uses a different IP range by default than Netgears)
Once booted up, navigate via your web browser to http://192.168.0.1 and enter the default username (admin) and password (password).
(in the browser address bar, instead of typing e.g. www.google.co.uk, just type 192.168.0.1)
If that doesn't work (it's possible the previous owner changed the default IP range to something else), hold in the reset button on the back of the Netgear router for a few seconds, and repeat the process. Hopefully that will get you onto the setup pages. I believe it has a setup wizard on first run after a reset. Enter your PN username and password and wait for it to finish configuring itself.
17-12-2011 12:26 PM
17-12-2011 1:23 PM
17-12-2011 2:18 PM
This what you need to do.
Log into router http://192.168.0.1 default username and password on base of router.
Click on Basic Setting on menu on left hand side.
Encapsulation is PPPoA (PPP over ATM)
Login is username@plusdsl.net
Password is the password you set up when you joined plus net
Idle time out I would put in 0
Then save
Click on ADSL settings in left hand side menu
Multiplexing Method is VC-BASED
VPI is 0
VCI is 38
DSL Mode I have on auto
Then save
Hopefully that should do the trick. Might need to reboot.
17-12-2011 2:30 PM
If all else fails do a factory reset
This involves pushing in the button (using a pencil or similar)
If you need the v4 manual shout up and I will attach it to a post as it is only 404kB
Quote Using the Reset Button
To restore the factory default configuration settings without knowing the administration password
or IP address, you must use the reset button on the rear panel of the router.
1. Press and hold the reset button until the Power LED turns red (about 6 seconds).
2. Release the reset button and wait for the router to reboot.
17-12-2011 2:37 PM
Their phone number is 0844 875 4000 if you bought your product within 90 days.
27-12-2011 10:54 PM
27-12-2011 11:54 PM
28-12-2011 9:49 AM
