lost broadband connection
- Re: lost broadband connection
01-06-2012 11:21 AM
Broadband light just flashes, have checked filters etc; all ok, according to plusnet everything ok with phone line. This started last week , had been fine up till then.
Any ideas, engineer can come and check butwould cost £60 if fault is our end, when trying to connect just get local only.
Message 1 of 3
(718 Views)
2 REPLIES 2
01-06-2012 11:28 AM
Sorry to hear about the issue with your connection. In all honesty it could be one of quite a number of things causing this so we'd need to continue with a fault investigation.
I've just had a look at ticket 55930074 and it looks like we're awaiting to hear back from you with regards to some fault checks.
Message 2 of 3
(352 Views)
01-06-2012 11:34 AM
Thanks for quick reply, have done all checks and still the same just broadband light flashing, Cannot connect even with ethernet cable.
Message 3 of 3
(352 Views)
