A bit of a strange one
leejonoloughlin
Hi guys,
First of all its been a while since ive had to ask for help! service is superb btw Smiley
Anyways got the adsl 2 change over done about a week or so ago and no matter how hard i try i cannot get any download speeds past about 12.5 mbps
heres the stats
results from bt speedter are
Download speed 12.16 Mbps this is a max ive had anything as low as 3.5
BT IP profile 18.52 Mbps
Plusnet line speed = 21 Mbps
Actual router sync speed =  20987
max attainable rate = 23940
snr 3.2
attenuation 20.5
something  just dosent add up to me i can understand not being full rate but to lose at least 4 Mbps no matter what the time of day the tests are run at seems real strange. yes there have been a few disconnects as i factory reset eveything on my router to makesure its not funky hardware but to no avail.
could you have a looky for me and see if there are any problems please
thanks
Lee
x47c
Re: A bit of a strange one
As a guess you are seeing lots of errors on the line.
But not enough to warrant the exchange raising the target margin to 6 - it's now clearly running at a 3 target
Lots of errors mean the router is spending it's time having to ask for the packets to be re-sent from the exchange and then re-assembling them - this reduces your speed considerably.
If so, this means the sync is higher than it really should be - and is an example of why higher sync does not always equate to higher throughput.
21CN/ADSL2+ does have a history of trying to run some lines too optimistically at a 3dB margin when they should be at 6.
Usually this problem only occurs at certain times rather than continuously.
Typical causes apart from a genuine fault on the line are:
- Increased noise on the line as evening/darkness approaches.
-  The dreaded REIN problem where someone nearby is using a defective electrical item which is dumping out Radio Frequency interference which is being picked up by your router.- and everyone else's in the neighbourhoood - 99.999% of whom will not care/notice
If you are having disconnections then that would suggest a fault - or that sometihing is dropping some really heavy RFI onto the line causing th BB signal to be temporarily obliterated.
What model of router are you using?
(I've had very similar problems as x47x described on a similar-length line. In my case resolved with some "tweaking" of interleaving to control the errors, but it's not a PN connection so they're things you maybe can't do, depending on the router)
Fixes: 10
Are you getting those speeds with a wired or a wireless connection to the router?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 68
We'd advise raising a fault if this is still an issue.
Please give us a shout when you have
 Adam Walker
leejonoloughlin
im actually using a tp link and the connection im on is wired through direct to the router , got a filtered faceplate as well. im still showing the same connection as last night and a flucuation in thourghput as normal.
ill try and grab a shot of my stats if you dont mind trawling through
Mode: ADSL_2plus
Traffic Type: ATM
Status: Up
Link Power State: L0
  Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (0.1 dB): 33 326
Attenuation (0.1 dB): 205 79
Output Power (0.1 dBm): 0 128
Attainable Rate (Kbps): 23972 1156
  Path 0  Path 1
  Downstream Upstream Downstream Upstream
Rate (Kbps): 20987 443 0 0
MSGc (# of bytes in overhead channel message): 51 12 0 0
B (# of bytes in Mux Data Frame): 249 13 0 0
M (# of Mux Data Frames in FEC Data Frame): 1 1 0 0
T (Mux Data Frames over sync bytes): 3 4 0 0
R (# of check bytes in FEC Data Frame): 0 0 0 0
S (ratio of FEC over PMD Data Frame length): 0.3806 0.9911 0.0 0.0
L (# of bits in PMD Data Frame): 5254 113 0 0
D (interleaver depth): 1 1 0 0
Delay (msec): 0.9 0.24 0.0 0.0
INP (DMT symbol): 0.0 0.0 0.0 0.0
Super Frames: 2664034 549141 0 0
Super Frame Errors: 0 0 0 0
RS Words: 0 0 0 0
RS Correctable Errors: 0 0 0 0
RS Uncorrectable Errors: 0 0 0 0
HEC Errors: 4294967289 191 0 0
OCD Errors: 18 0 0 0
LCD Errors: 0 0 0 0
Total Cells: 2145989443 872330 0 0
Data Cells: 4699530 42930 0 0
Bit Errors: 0 0 0 0
Total ES: 219 0
Total SES: 0 0
Total UAS: 31 4294967267
If its the router then i think i may change as ive always had my own and it may be more reliable getting a plusnet approved one. Then again this router has one hell of alot more info than im used to with the router so im only grabbing snippets of the info i understand.
what do you guys think? or is it a line problem thats going to need a ticket?
cheers
lee
HEC errors seem to be VERY high. Possibly pointing to the problem - cause and resolution might be trickier.
I'd contact support as requested by AW.
leejonoloughlin
Ok adam submitted a request via the broadband troubleshooter, boy is that longwinded what do hec errors point to btw?
Fixes: 10
HEC errors is strange - but doesn't look like it's a genuine high figure as it is very close to 232 - more like it's gone negative
leejonoloughlin
yeah i know what you mean as i can see test were done about 20 mins ago as the router went off/ on to adsl 1 then back to adsl 2 and it looks as if the errors are the same  good newsis the upstreams gone to only 6 errors
