loss of speed
- Re: loss of speed
loss of speed
05-05-2015 10:30 PM
I have over the last few weeks lost my usual speed. I have been running for a long time at about 5Mbps and am now on 3.2 Mbps, I cant find any way to get into contact with anyone at PN except by phone which is not a good alternative for me. Can any one help.
Message 1 of 7
(1,222 Views)
6 REPLIES 6
Re: loss of speed
06-05-2015 9:42 AM
Has anything changed in your property over the last few days? The connection looked fine until the 3rd then as the graph below shows your line started disconnecting.
I'd recommend running through our troubleshooter using the link below.
https://faults.plus.net
Message 2 of 7
(686 Views)
Re: loss of speed
07-05-2015 3:38 PM
Ok willdo thanks. Ted
Message 3 of 7
(686 Views)
Re: loss of speed
08-05-2015 10:38 PM
hi done all usual things filter etc. I disconnected in my router stats and switched off my router for 1 hour. I now have "bandwidth" 443/5624 , on my router and the speed showing on speed tester is ping 17ms Down 4.66 Mbps, up 0.37Mbps. Is this my best or can I try some thing else. Ted.
Message 4 of 7
(686 Views)
Re: loss of speed
09-05-2015 1:30 AM
Hi Ted,
What are your speeds like now? I think your Speed Profile (done automatically on our end) just needed updating at the time you ran your last test, this should have done it itself now, so I'd be interested in how your connection has performed.
Message 5 of 7
(686 Views)
Re: loss of speed
09-05-2015 10:11 PM
Today 22:05 4654 kbps (582kB/s) 367 kbps (45.9kB/s)
speed test as above
router showing as below
Uptime: 2 days, 5:33:22
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,104 / 5,464
Bandwidth (Up/Down) [kbps/kbps]: 443 / 5,624
is that any help. thanks Ted
speed test as above
Message 6 of 7
(686 Views)
Re: loss of speed
11-05-2015 4:59 PM
Message 7 of 7
(686 Views)
