internet speed not matching what i pay for
paddythebaddy
whilst hard wired into the hub im only getting 35mbps download and 9mbps upload yet I'm paying for between 48 - 58mbps.
how can i fix this ? what can be done ?
6 REPLIES 6
Fixes: 334
Re: internet speed not matching what i pay for
@paddythebaddy When did you first notice this, and what do you usually get? Welcome to the forums, BTW.
paddythebaddy
thanks and its never been the fastest of connections tbh but its today i thought i would actually action it after a day of waiting forever on stuff to upload and download (working from home)
Fixes: 334
OK.
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
Mustrum
Fixes: 81
Just to add to the above, are you really on Full Fibre? If not how is your phone line? Is it quiet when you dial 17070 option 2?
And are you testing over Wi-Fi, via home plugs or direct via ethernet?
Edit, ooops just noticed John already asked about the quiet line test!
Fixes: 334
@Mustrum I doubt the OP is actually on FF - I've requested the mods to move this to Broadband. The phone question is covered in my script.
& I missed your edit. 😀
Fixes: 457
Moderator’s Note
This topic has been moved from Full Fibre to Broadband.
