Broadband down
Bucketinabag
Broadband down
Broadband has been down her (WR14) for around 3 hours. Anyone got any information?
Tags (1)
5 REPLIES 5
Fixes: 377
Re: Broadband down
Just yours? And how 'down'?
Bucketinabag
Re: Broadband down
Orange light and "b" completely down. Not sure if others in the area are down
Fixes: 377
Re: Broadband down
OK. Sounds like you do have a problem. To check if it is a widespread issue, or just you, put your full phone number into this link: https://status.zen.co.uk/broadband/
If it IS just you, follow this:
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
Bucketinabag
Re: Broadband down
Line is clear, I've put in a report via text, thank you
Fixes: 377
Re: Broadband down
OK. Just be aware it won't get picked up until tomorrow morning.
