intermittent connection drops
Fixes: 1,662
Re: intermittent connection drops
Ah no problem. I've ran another test and it's still showing out of sync so seems to rule out a modem fault as you've effectively tried two. I think it's worth arranging an engineer to take another look. You still free anytime Monday to Friday?
Austen88
I am. WFH so always around. Anything else you want me to try before going for an engineer?
Fixes: 1,662
Cool. There isn't much to try other than what you've done already apart from making sure things are set up correctly: https://www.plus.net/help/broadband/connection-troubleshooting/
Actually you could try plugging the hub or modem into the test socket found behind the faceplate of the master socket: https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Austen88
Guess what, plugged into the master with a filter and got a solid adsl light! Guess it must be a wee bit loose with the face plate.Once again thank you!
Fixes: 1,662
Nice! Saved an engineer a visit haha.
No problem let me know if you need any further help. Cheesy
Austen88
🧙‍♂️ Cheers again. Have a great week (once again).
Austen88
I don't know what happened to my wizard emoji sorry.
Fixes: 1,662
Emoji's are a thing of the past. Gif's are the way forward. Cheesy
Gandalf Nod GIFs - Get the best GIF on GIPHY
Cheers, have a good week as well!
