Plusnet SMTP server Blacklisted
knowdice
Can somebody at Plusnet get the Plusnet SMTP server un-blacklisted as below:
Diagnostic-Code: smtp; 550-Rejected because 212.159.14.20 is blacklisted. Contact [email protected]
This IP is blocked due to several reasons. To get unblocked, you should contact abusix: https://lookup.abusix.com/
Kind regards
Martin Schlatter
Abuse Desk Specialist
Hostpoint Abuse Team <[email protected]>
3 REPLIES 3
Fixes: 1,662
Re: Plusnet SMTP server Blacklisted
There's probably more going on here than meets the eye otherwise we'd likely be seeing masses of people not able to send mail. Do you get a bounceback which begins with "This is an automatically generated Delivery Status Notification"?
knowdice
This was to a Swiss email address and checking on https://lookup.abusix.com/ it showed 212.159.14.20 as blacklisted.
Checking using on abusix.com now:
IP 212.159.14.20 is listed.
This means that action needs to be taken to resolve the issue! Don’t worry, Abusix is here to help.
But emails are no longer bouncing...😀
Maybe not many ISPs use Abusix...
Fixes: 1,662
Ah fair enough. No worries, glad that all seems to be well now. Smiley
Let me know if there's anything else you'd need help with.
