connection keeps on dropping connection
felicity2802
hello,
My internet connection keeps on dropping maybe every two days. Its done it for ages but is getting really annoying now as it has to be reset every time. Why does this keep happening? I've never experienced this with any other network.
4 REPLIES 4
Fixes: 384
Re: connection keeps on dropping connection
@felicity2802 Can you confirm you are definitely on an ADSL and not FTTC connection - the remedy procedure is slightly different on both?
felicity2802
hey, is ADSL
Fixes: 384
OK. If ADSL, try following this as far as possible.
 If you would like help from the community, a good starting point is to have a look at This post and supply as much detail from it as possible.Sight of the HelpDesk page, under the Troubleshooting tab on your router homepage - with personal information redacted - is very useful.
It would also be a good idea to carry out a 'Quiet Line Test' - dial 17070 from a (preferably corded) phone and select option 2 - there should be no discernable noise. If there is, report a phone fault first, as without a clear phone connection, your broadband will not perform correctly.
It may be an idea to also report your lines capabilities - please post your results from THIS site, but ensure your phone number is obscured/hidden.
Also please report the 'Advanced Diagnostics' output from Here
If you reply to this topic with as much detail as possible, there are plenty of experienced members who can advise on possible remedies.
TheMightyAJ
Fixes: 126
Hi @felicity2802,
I'm sorry to hear that you're experiencing issues with your connection. I've tested your line this afternoon and I can see that there is definitely a fault affecting the services, though multiple line tests seem to suggest the issue lies within the property. Have you had a chance to carry out the troubleshooting tips recommended by @jab1? In addition to the suggestions he has made, I would recommend setting the router up within the test socket in the property, to see if this results in any improvement. For reference we have a guide on this here.
 Alex H
