can't connect no ethernet connection
Fixes: 124
Re: can't connect no ethernet connection
This is a ADSL modem/router only
What is the Internet LED (third from left) doing?
On - Internet connection is available.
Flash -  There is data being transmitted or received via the Internet.
Off  - No successful Internet connection is available
Edit: If the LAN lights are flashing, this will be normal if a device is connected to one
Fenster
"Server not found" mobile phone won't connect with my modem wireless either.
When opening email site get a bunch of info, server error, network responder error. Had this problem loosing Internet a while. Try after 10 minutes then it connects only to drop again but it's stopped completely now. You see the diagnostics I ran ubove? Four ATM OAM Fails.
Oh I can do the "desktop site" now but there still nothing to click to attach. Thanks
Fixes: 334
On the desktop site 'reply' window, do you not see this:Screenshot 2024-03-01 at 17-20-55 Re can't connect no ethernet connection.png
Click the 'mountain' icon between the smiley and the camera, and follow the prompts.
Fenster
That's the'internet' light off cause well no Internet.
Lan rapid constant flashing but no traffic, errors 'no ethernet'. Computer is still connected and I can log on to the modem.
What you mean adsl/router only? Adsl 2+ I posted earlier.
Thanks for help
Fixes: 334
@Dan_the_Van 's comment was to point out that you have an ADSL rather than FTTC connection, but I'll leave it to him to diagnose your problem - I'm out for most the rest of the day.
Fixes: 124
I suggest you check the broadband connections parameters are correct
Fenster
Yes I see it now thanks!
Fenster
OK I was not being funny just didn't know what he meant. Thanks for all help Jab
Fenster
Openreach engineer has been and the problem was in the street box. He fixed it and I now have the internet working again. Had a look at the modems diagnostics and it is still showing the 'Fails' (see image).
Anyone know why this is? Thanks
Fixes: 124
If the internet is working I would not worry about those fail messages, it could just be the  ADSL terminal equipment does not support OAM cell test
Dan
Fenster
Thanks for the reply. Engineer fixed the problem thank goodness. Appreciate everyones help. Will now mark this issue solved.
