browser session closing unexpectedly daily-since change from BT
- Re: browser session closing unexpectedly daily-sin...
19-03-2014 7:39 PM
Hi
We have had Plusnet fow a few weeks now. We had Bt with a home hub previously
In terms of equipment everything remains the same except we now have the Plunet wifi router-All seems good , except for one thing-Everyday at least once a day we lose our browser-a message comes up stating “ your last browsing session closed unexpectedly..” This was something we rarely saw with BT
-what is causing it?
Message 1 of 9
(1,158 Views)
8 REPLIES 8
Re: browser session closing unexpectedly daily-since change from BT
19-03-2014 7:51 PM
That is generally caused by a problem with the browser or a misbehaving website etc rather than your ISP.
Have you done a full virus and malware scan recently ?
Message 2 of 9
(781 Views)
19-03-2014 7:54 PM
Ta for respondin
full security up to date etc
my partner has an Ipad and hers ipad stops at same time as I get Browser stopping unexpectedly
Message 3 of 9
(781 Views)
19-03-2014 7:58 PM
I assume it's IE that you're using since that's the error you get when it crashes, have you tried any other browsers (Chrome, Firefox)?
Message 4 of 9
(781 Views)
19-03-2014 8:00 PM
Yes I have only been using IE
Message 5 of 9
(781 Views)
19-03-2014 8:02 PM
I'm inclined to say it's a corrupt IE file but when you mentioned that your iPad is also affected, I won't put all my money on that being the final answer!
Can you tell us what version of windows and IE you're using?
MS do recommend doing the following reset to get rid of the error on IE
Open Internet Explorer
Click on Tools
Click on Internet Options
Click on Advanced
Click on Reset
Reboot the computer
Click on Tools
Click on Advanced
Click on Reset
Reboot the computer
Message 6 of 9
(783 Views)
19-03-2014 8:04 PM
You could also rule out the Plusnet router by going back to your Home Hub.
http://community.plus.net/library/hardware/using-a-bt-homehub-3-or-2-on-plusnet-adsl-or-fttc/
Message 7 of 9
(783 Views)
19-03-2014 8:06 PM
Oh I can use the home hum
will try later ta
will try later ta
Message 8 of 9
(783 Views)
19-03-2014 8:09 PM
I am hopeless at this and my typing is dreadful
look thank you to everyone
I will try what has been suggested=I can see an unhappy partner soon when no doubt I break the whole thing
ta anyway
bye
ta anyway
bye
Message 9 of 9
(783 Views)
