Work VPN occasionally dropping
Fixes: 385
Re: Work VPN occasionally dropping
OK, thanks @MisterW  - I  never claim to be even a novice at networking. 😉
stef12
I’m just logging on to my work laptop to see what happens.
Apologies in advance if this has fixed it and you’ve all gone to this level of trouble to help.
stef12
Right, I’m happy, but also embarrassed to report that moving the cable from the WAN to the other port has fixed the issue.
I blame the Ethernet cable having a yellow tip which corresponded to the WAN! But also it’s obviously a huge oversight on my part.
Fixes: 385
Never had a PN Hub, but I thought the WAN  port was red?
@stef12
Let's hope all is well now, it was interesting to get to the bottom of the issue.
It was a joint effort with myself, @MisterW and @Townman who braved testing out our theory of what was happening.
stef12
Mine’s yellow!
@jab1
The ports are marked up 1 2 3 WAN.
The word WAN is on a red label above the port and is next to the DC cable socket
Fixes: 385
OK @Dan_the_Van - thanks. I'm sure there used to be pictures of the backs of the Hubs on the PN help pages, but not any more, and I, obviously mistakenly thought the Hub2, at least had a red WAN port.
No matter - the OP is sorted.
outcast
Aspiring Champion
Fixes: 19
outcast
Aspiring Champion
Fixes: 19
@stef12 wrote:
The WAN is attached to my Sky box and the other cable is connected to my cat flap hub.
The mention of the ethernet connected cat flap, reminded me of @MJN 's cat feeder on the original Plusnet IPv6 trial in 2011
... and nearly fifteen years later, Plusnet still haven't rolled out IPv6 !
@stef12  -  Just out of curiosity, did the Sky box's internet connection actually work ?.
MJN
Seasoned Pro
Fixes: 5
Worse still, we were all nearly 15 years younger back then! Where has the time gone!
stef12
It did, yeah! It wasn’t as fast as when we had Sky broadband prior to this, but it worked most of the time. Just used to freeze occasionally when streaming on iPlayer etc.
outcast
Aspiring Champion
Fixes: 19
@stef12  - just checking, now that an entire week has gone by, has your problem been completely resolved ?
stef12
Hi, thankfully all seems to be okay, thank you.
