Losing internet on Hub 2
Savbo
Hi all, new here, we have been with Plusnet for a few months. First Hub 2 was often difficult for our Apple devices and new Asus laptop to connect to, lots of spinning icons, and when we did connect there was often no internet. After trying for weeks we contacted Plusnet and they said router was probably faulty, so sent a new one. That was good at first but now increasingly having same problem, especially with Asus. Any ideas?
Savbo
25 REPLIES 25
Fixes: 383
Re: Losing internet on Hub 2
@Savbo A wild thought - what user name is displayed on your Hubs Broadband - Internet page? If it is yours, don't post it here, just say 'mine'.
mystreet1
Seasoned Pro
Fixes: 7
@Savbo also make sure nothing is plugged in the WAN port (usually red) if you are on FTTC.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Savbo
Now I am confused! Where does the connection to the Openreach box go if not the WAN socket? That’s what the instructions for the Router say to do?
Fixes: 383
So, @Savbo  - you are on an FTTP connection?
Savbo
Thanks, it’s mine, though it wasn’t when I spoke to Plusnet a couple of weeks ago, they talked me through correcting it
Savbo
Yes, with the Openreach box
Fixes: 383
OK. So  have you checked your username and password in the Hub are correct?
Savbo
Yes they appear to be correct. The ‘No internet, secured’ status is intermittent. Also, we have a TPLink extender connected to the Hub 2 and it seems to work almost all the time?
Fixes: 383
That is another of my thoughts trashed, then. I seem to recall having a similar issue many years ago, and solving it, but I can't remember the solution, except to think it was a setting somewhere in the Windows environment. Can't check now, as I don't use MS hardware.
Savbo
Thanks for trying! It affects both the laptop and our Apple devices - when I last spoke to Plusnet it was the laptop that was having trouble and they said it must be an issue with that.
I haven’t tried Factory Reset yet, is that a wise move?
Michael
Fixes: 383
A factory reset of the laptop? If so, I am reluctant to advise, as my last Windows OS was W7 on a machine that gave me no real issues. Which Windows OS are you using?
outcast
Aspiring Champion
Fixes: 19
@Savbo -
  1. What speed tier is your Plusnet Full Fibre package ?
  2. Have you tried using your Asus laptop when connected directly to the router with an Ethernet cable ?
  3. Do you have any other spare routers available, perhaps from previous ISPs ?
  4. What model of TP-Link extender are you using ?
Fixes: 580
Ah! the old Tplink DHCP problem
@Savbo there's an issue with some versions of Tplink extenders. Even though they are confiured in 'Access point mode' with their DHCP server supposedly disabled, they will occasionally re-enable their DHCP server when they 'think' there's no other DHCP server on the network.
First check that there is no problem with the TPlink disconnected. Then make sure the tplink has the latest firmware.
Fixes: 383
Personally, I don't think it is a speed/connection issue - it certainly wasn't for me, and the first non-AI generated response I got on searching (from MS themselves) suggested it was specific-machine related.
