Wireless connection
fgorwood
Wireless connection
Please could you help me. I’m a teacher trying to work from home on Google Apps such as Google drive. I cannot upload any files to google drive and when working online my connection constantly drops (usually immediately when I open google drive/docs or slides). I have been a plus net customer for a number of years but only ever had an updated router once. Could this be causing the problem? Please advise as at the moment it is proving impossible for me to use the internet for work at home.
Many thanks
F Gorwood
30 REPLIES 30
Legend
Fixes: 255
Re: Wireless connection
@fgorwood Welcome to the forums. Which router do you have, and what is your speed like? If you give us that information, we can possibly make suggestions. Is it possible to use an ethernet connection?
fgorwood
I have used an Ethernet cable but still have the same problem trying to upload anything. My router is a Plusnet 2704N but I’m not sure how to find the speed ?
Legend
Fixes: 255
Thanks for coming back, @fgorwood . If you are on ADSL, trying to upload whilst simultaneously download, you will almost certainly fail, especially using the 2704N - it suffers from excessive 'buffer-bloat' which will effectively lock it up.
To determine your speed run https://speedtest.btwholesale.com/ , ensuring you run the 'further diagnostics', and paste thefinal results into a reply.
fgorwood
Please see attached image. I can't seem to find out my Broadband ID or access line ID so have not been able to run the further diagnostic test. I don't know if the attached file helps?
Legend
Fixes: 255
No file attatched - and you use your landline phone number in the correct field.
fgorwood
Here is the performance test report. Many thanks for trying to help.
Legend
Fixes: 255
OK - those figures don't look too good, so we need to delve a little deeper.
 A good starting point is to have a look at THIS  post and supply as much detail from it as possible.
It would also be a good idea to carry out a 'Quiet Line Test' - dial 17070 from a (preferably corded) phone and select option 2 - there should be no discernable noise. If there is, report a phone fault first, as without a clear phone connection, your broadband will not perform correctly.
If you reply to this topic with as much detail as possible, there are plenty of experienced members who can advise on possible remedies.
Sorry the process is long-winded, but without PN staff support, the Community members have to work on the information we can get.
Mustrum
Fixes: 77
@fgorwood what is your line capable of?
If you enter your number in the dsl checker below, post the results making sure you hide your number:
BT Broadband (btwholesale.com)
Legend
Fixes: 255
Thanks, @Mustrum - that would be a further question I would ask, if the results from my request threw up queries - often, I have found they don't need to go that far as the reports requested usually pinpoint an obvious error.
Mustrum
Fixes: 77
@jab1  i just thought it would be good to know what the OP was working with. Looking at the IP profile, it would be a struggle running those apps even if they were getting close to those speeds, hence looking to see if there was any other options.
Legend
Fixes: 255
OK @Mustrum , I see your point - and have just added the request for future queries of this nature to my template, so thanks.
fgorwood
  • The previously attached information was when I was using and ethernet cable. I can barely keep a wifi signal to run the test without.
I think below is the line speed
  • Estimated Download Range: 1.5 - 4Mbps
  • Estimated Upload Range: 1Mbps
  • Minimum Guaranteed Speed: 0.8Mbps
  • Current Line Speed (Download): 4Mbps
Attached is the BT speed test
I can't find is the Router stats - noise margin, speed and attenuation (upstream and downstream). The link takes me to the FAQ page
fgorwood
Sorry just to say I don't have a phone attached to the landline but I did ask for a line test not so long ago and there was no problem with it apparently.
Legend
Fixes: 255
OK. From what you have posted, @fgorwood , you appear to be at the end of a VERY long line out in the wilds, Hopefully, a look at your availability report will confirm this.
