Will Plus net still work if i get rid of my old pc?
- Re: Will Plus net still work if i get rid of my ol...
14-08-2008 1:36 PM
I want to replace my old pc which has plusnet installed on it.
Will Plusnet work on a new pc?
Message 1 of 7
(1,493 Views)
6 REPLIES 6
Re: Will Plus net still work if i get rid of my old pc?
14-08-2008 1:42 PM
Plusnet broadband is not PC dependant, so you will be OK with a new PC.
BUT!! If you are connected to Broadband via a USB router, you will have to re-install the drivers. If the USB router is more than a few years old, the drivers may also not be Vista compatible.
Post up the details of what you currently have and are planning to get as a new PC and I'm sure we can help you a bit more.
Maurice
Maurice
Message 2 of 7
(467 Views)
14-08-2008 5:13 PM
It's also worth mentioning that if you are using a USB modem and are looking at getting a Vista enabled PC, the modem may not be supported.
Message 3 of 7
(467 Views)
14-08-2008 6:02 PM
Thanks for the replies
I have Windows XP.
If I do buy a new one it is most likely to have Vista installed on it.
Also I connect to broadband via a USB router
My USB router is only 8 months old.
It's a BT Voyager 210.
Could you confirm whether it should work on a new PC with VIsta and connected via USB? and also the drivers will still be compatible
I have Windows XP.
Message 4 of 7
(467 Views)
14-08-2008 6:05 PM
If its a Voyager 210 it should have ethernet as well. So I would recommend to use ethernet, no drivers to install just plug and go. As the login details will already be stored in the router as soon as its plugged in to the new PC it should work!
Message 5 of 7
(467 Views)
14-08-2008 6:48 PM
A new Vista computer will almost certainly have a network (Ethernet) card installed - in fact make sure you get one that has. The Voyager 210 has a single Ethernet port which would connect to your new computer just fine without needing any special drivers installed. The 210 should have come with the required Ethernet cable in the box (I can't remember whether it is coloured yellow or blue).
Whilst the 210 also has a USB port I don't think the drivers provided are compatible with Vista - and as far as I know there aren't any updates which are compatible.
David
Message 6 of 7
(467 Views)
14-08-2008 7:18 PM
I would use Ethernet anyway, its much better than USB in my view.
Message 7 of 7
(467 Views)
