Wifi left by estate agents not working
RuthBriggs
Wifi was left in my house house for us however it is showing a blue light but doesn’t work. Diagnosed issue that the account is with the setup login however we do not have a plusnet account to use. What do we do?
17 REPLIES 17
Fixes: 357
Re: Wifi left by estate agents not working
@RuthBriggs You need to create an account with Plusnet.
Give them a call on 0800 432 0200
Fixes: 105
@RuthBriggs
If the estate agents left an active internet service then all you need to do is to get the SSID and password for WiFi from them.
If you have a laptop with an ethernet connection you could plug that in to check the service is active.
Fixes: 357
But who pays for it, @bmc ?Huh
Fixes: 1,491
Sounds like it's included in the rent - and maybe the issue is that it's the setup@plus.. username issue.
@RuthBriggs - have you tried factory resetting the router by holding a pin in the back? If the router is registered to an account hopefully that will kick start the automated process.
Fixes: 357
Didn't think of that, @dvorak - but the OP said 'Estate Agent', not landlord? So i kind of thought they had bought the house.
Fixes: 1,491
Fair point @jab1 - estate agents can do both.
But would it even authenticate with the setup username if there was no active account? Confusing Smiley
Fixes: 357
Agreed, @dvorak  - but to my mind we need more information from the OP, otherwise we're just guessing - not a good strategy.
Fixes: 105
@jab1 @dvorak
The blue light suggested to me there was / is an active connection. A wired device, as suggested, would confirm this.
RuthBriggs
I’ve tried resetting with no luck unfortunately
RuthBriggs
No I rent the house, sorry for the confusion
RuthBriggs
It’s active but when you connect there is no wifi unfortunately. Think it’s an issue of no account connected
Fixes: 357
If you rent, and the internet connection comes with the rent, you need to ask  the estate agent/landlord what the account name is, and enter that where it currently says 'setup'
Fixes: 105
@RuthBriggs
If you have a blue light then there is a conencted accout which is active. Do you have a wired device you can try?
Have you checked with the estate agents what the WiFi SSID and password is?
Fixes: 357
@bmc If the 'accountname' is 'setup...' then sorting that is more important. SSID and p/w is on the Hub.
