Wifi left by estate agents not working
Fixes: 334
Re: Wifi left by estate agents not working
@RuthBriggs As I said above, for the connection to work, the 'setup@plusdsl' field needs to be changed to the proper 'accountname' and the password field needs to have the associated password entering. The Estate Agents should have this information, or to be able to obtain it from the Landlord.
Fixes: 87
@RuthBriggs
If you have a wired device to try and get a connection have you got the white card usually found on the back of the router.
If you have type 192.168.1.254 in the address bar and then try the Admin password shown on the card.
Fixes: 334
@bmc I'm not convinced this will work with 'setup' as the username.
