What would cause TG582n to to lose WiFi on all devices at the same time
- What would cause TG582n to to lose WiFi on all dev...
Re: What would cause TG582n to to lose WiFi on all devices at the same time
24-02-2014 5:33 AM
Quote from: Kelly TORPC: So, so confirm this post: http://community.plus.net/forum/index.php/topic,122856.msg1074747.html#msg1074747 shows the log of when it happened again on a router with no cli changes made to it and it was a complete ethernet and wireless drop out?
I feel as though PlusNet are not really interested in solving this long time known issue that PlusNet has clearly known in excess of 12 Months
I am honestly exhausted of troubleshooting & getting absolutely know where with PlusNet staffs feedback
Please do not make me have to retract the statement I made in a thread / poll I started
Have Plusnet got your full support
Add to that
PlusNet do not I repeat DO NOT have to put up with several screaming females when the connectivity drops on their devices
I hope PlusNet will send out some industrial strength ear plugs & some headache tablets, due to their inconsistent support on this known issue
adie:green fixed messed up link]
24-02-2014 9:42 AM
Members of my team regularly review hardware replacement tickets and test hardware to make sure this sort of thing gets seen, and we've only see this being reported on here. It's likely the vast majority of our customers either don't trigger this issue, or it happens infrequently enough for it not to be noticed in the general faults noise. Bear in mind this router is also in use across the world in far larger quantities than we ship out demonstrate it to be a low impacting issue.
Associating it as a later hardware issue and possibly to do with the DNS resolver is useful though. That's something we can talk to Technicolor about.
Ex-Broadband Service Manager
24-02-2014 9:46 AM
I didn't notice it was messed up
Cheers Kelly
However it would of been nice to have had a acknowledgement of our responses to the question(s) you asked for
Even a simple thank you for responding would of sufficed to let us know you had not abandoned us
Edit:
Although it is early days
Since changing the DNS Resolver I have had NO dropouts & still on the other setting as mentioned above
24-02-2014 9:53 AM
24-02-2014 9:59 AM
Water under bridge
Start afresh
24-02-2014 10:23 AM
Just a thought
If / we find a fix / workaround
Can we have it turned into a sticky ?
I will test the DNS Resolver issue on the USB TG582n flashed 10.2.2.B Firmware at a later stage / If we get that far
Then I will test the other 2 NON USB 10.2.2.B Routers accordingly
24-02-2014 10:26 AM
24-02-2014 10:29 AM
Sorry Chris / Kelly I could not resist the temptation
Cheers Chris
I am feeling optimistic on the DNS Resolver change atm
24-02-2014 8:47 PM
24-02-2014 11:31 PM
25-02-2014 1:35 PM
Did not need any manual intervention to restore as the connectivity had restored itself
Quote Info Feb 25 13:14:24 LOGIN User admin logged in on [HTTP] (from 192.168.1.73)
Info Feb 25 13:12:06 CONFIGURATION saved by TR69
Info Feb 25 13:11:46 FIREWALL event (1 of 1): deleted rules
Warning Feb 25 13:11:45 PPP link up (Internet) [IP Address removed]
Info Feb 25 13:11:45 PPP CHAP Chap receive success : authentication ok
Info Feb 25 13:11:45 PPP CHAP Receive challenge (rhost = PCL-AG06)
Info Feb 25 13:11:44 PPP CHAP Receive challenge (rhost = bras-red9.cf-c)
Info Feb 25 13:11:36 xDSL linestate up (ITU-T G.992.5; downstream: 9890 kbit/s, upstream: 732 kbit/s; output Power Down: 20.7 dBm, Up: 12.2 dBm; line Attenuation Down: 47.5 dB, Up: 27.1 dB; snr Margin Down: 3.1 dB, Up: 5.0 dB)
Warning Feb 25 13:11:28 PPP link down (Internet) [IP Address removed]
Info Feb 25 13:11:07 xDSL linestate down
Info Feb 25 13:10:49 FIREWALL event (1 of 1): modified rules
Info Feb 25 13:10:49 FIREWALL event (1 of 1): created rules
Info Feb 25 13:10:48 Feb 25 13:10:48 xDSL linestate down
Error Feb 25 12:53:36 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 125.39.31.175 [China Unicom Tianjin Asia] Dst ip: [IP Address removed] Type: Destination Unreachable Code: Communication with Destination Host is Administratively Prohibited
Looks like we may have a possible trigger & the DNS Resolver change was for the better good
Can PlusNet please review my stats to compare with this latest dropout
3CSyslog is reporting exactly the same
Just need to find out why the XDSL keeps failing ?
25-02-2014 1:40 PM
25-02-2014 1:46 PM
What could be the reasons why the the XDSL keeps failing ?
also wondering as I can not remember if Penfold mentioned it
Did Penfold suffer from the the XDSL keeps failing
Or
Was it something different ?
25-02-2014 2:09 PM
Quote from: Dandroid Looking at your logs you had a linestate down at 15:41
Info Feb 19 15:41:00 xDSL linestate down
Warning Feb 19 15:41:35 PPP link down (Internet) [87.112.139.184]
Info Feb 19 15:41:47 xDSL linestate up (ITU-T G.992.5; downstream: 9917 kbit/s, upstream: 708 kbit/s; output Power Down: 20.7 dBm, Up: 12.1 dBm; line Attenuation Down: 47.5 dB, Up: 27.1 dB; snr Margin Down: 3.1 dB, Up: 5.0 dB)
Info Feb 19 15:41:55 PPP CHAP Receive challenge (rhost = bras-red9.cf-c)
Info Feb 19 15:41:55 PPP CHAP Receive challenge (rhost = PTW-AG01)
Info Feb 19 15:41:55 PPP CHAP Chap receive success : authentication ok
Warning Feb 19 15:41:56 PPP link up (Internet) [IP Address Removed
Info Feb 19 15:41:56 FIREWALL event (1 of 1): deleted rules
Info Feb 19 15:42:11 CONFIGURATION saved by TR69
You also had one on the 14th
Info Feb 14 18:08:51 xDSL linestate down
Could this be the start of your issue and your wireless devices are not recovering from the internet connection being lost?
I did post I thought the was the cause of your issue last week.
Hopefully you have a fix now
25-02-2014 2:15 PM
