What would cause TG582n to to lose WiFi on all devices at the same time
TORPC
Re: What would cause TG582n to to lose WiFi on all devices at the same time
It is 6 days since Kelly asked & we have answered
Quote from: Kelly
TORPC:  So, so confirm this post: http://community.plus.net/forum/index.php/topic,122856.msg1074747.html#msg1074747 shows the log of when it happened again on a router with no cli changes made to it and it was a complete ethernet and wireless drop out?
I feel as though PlusNet are not really interested in solving this long time known issue that PlusNet has clearly known in excess of 12 Months
I am honestly exhausted of troubleshooting & getting absolutely know where with PlusNet staffs feedback
Please do not make me have to retract the statement I made in a thread / poll  I started
Have Plusnet got your full support
Add to that
PlusNet do not I repeat DO NOT have to put up with several screaming females when the connectivity drops on their devices
I hope PlusNet will send out some industrial strength ear plugs & some headache tablets, due to their inconsistent support on this known issue
adie:green fixed messed up link]
Kelly
Fixes: 9
Quite the opposite, I've read this thread every day as you've worked your way through it.  There isn't much point contributing when we don't have anything further to add.
Members of my team regularly review hardware replacement tickets and test hardware to make sure this sort of thing gets seen, and we've only see this being reported on here.    It's likely the vast majority of our customers either don't trigger this issue, or it happens infrequently enough for it not to be noticed in the general faults noise.  Bear in mind this router is also in use across the world in far larger quantities than we ship out demonstrate it to be a low impacting issue.
Associating it as a later hardware issue and possibly to do with the DNS resolver is useful though.  That's something we can talk to Technicolor about.
Kelly Dorset
Ex-Broadband Service Manager
TORPC
Thanks for fixing the link dvorak
I  Embarrassed didn't notice it was messed up
Cheers Kelly
However it would of been nice to have had a acknowledgement of our responses to the question(s) you asked for
Even a simple thank you for responding would of sufficed to let us know you had not abandoned us
Edit:
Although it is early days
Since changing the DNS Resolver I have had NO dropouts & still on the other setting as mentioned above Wink
Kelly
Fixes: 9
Sorry if you felt ignored, not the intention!
Kelly Dorset
TORPC
Cheers Kelly
Water under bridge
Start afresh Wink
TORPC
@Kelly
Just a thought
If / we find a fix / workaround
Can we have it turned into a sticky ?Huh
I will test the DNS Resolver issue on the USB TG582n flashed 10.2.2.B Firmware at a later stage / If we get that far Smiley
Then I will test the other 2 NON USB 10.2.2.B Routers accordingly
Chris
Legend
Fixes: 169
If we find a fix/workaround I'm happy to get it in the Library so it's searchable easily: http://community.plus.net/library/
TORPC
Are Chris & Kelly the one & the same person  Wink  Roll_eyes
Sorry Chris / Kelly I could not resist the temptation  Wink
Cheers Chris
I am feeling optimistic on the DNS Resolver change atm
penfold
Fixes: 5
Thanks kelly. I would be interested in technicolors comments tbh. This does happen to other users there are some posts on the o2 forum. I do suspect however that replicating this issue will be difficult if not impossible as we have no idea of the actual trigger, if indeed there is a trigger for the issue. Most people probably think there is something wrong with the internet and go off and do something else. I have noticed that when this happened websites I used alot were affected but ones I almost never use loaded up fine, but other times all sites were inaccessible. Things are going well after disabling the dns resolver.
30FTTC06
Fixes: 4
Nice to see this issue being taken into account at last. I still use the forwarder on my TG582n to force open-dns requests through,  as well as it being a secondary dns address for some of my equipment, so i leave mine enabled. life isn't quite so simple as just being able to turn it off!, but, as long as my alternative cache behaves, everything ticks along nicely thank you very much. I think another bonus to the whole resolver fiasco is if everything worked perfect first time around, I would never have discovered add-blocking network wide. I can't tell you how nice it is to be able to browse the web or play a video on youtube without adverts or crap popping up on whichever pc or device i use!
TORPC
Just had a brief droput on all WiFi & Ethernet devices
Did not need any manual intervention to restore as the connectivity had restored itself  Smiley
Info Feb 25 13:14:24 LOGIN User admin logged in on [HTTP] (from 192.168.1.73)
Info Feb 25 13:12:06 CONFIGURATION saved by TR69
Info Feb 25 13:11:46 FIREWALL event (1 of 1): deleted rules
Warning Feb 25 13:11:45 PPP link up (Internet) [IP Address removed]
Info Feb 25 13:11:45 PPP CHAP Chap receive success : authentication ok
Info Feb 25 13:11:45 PPP CHAP Receive challenge (rhost = PCL-AG06)
Info Feb 25 13:11:44 PPP CHAP Receive challenge (rhost = bras-red9.cf-c)
Info Feb 25 13:11:36 xDSL linestate up (ITU-T G.992.5; downstream: 9890 kbit/s, upstream: 732 kbit/s; output Power Down: 20.7 dBm, Up: 12.2 dBm; line Attenuation Down: 47.5 dB, Up: 27.1 dB; snr Margin Down: 3.1 dB, Up: 5.0 dB)
Warning Feb 25 13:11:28 PPP link down (Internet) [IP Address removed]
Info Feb 25 13:11:07 xDSL linestate down
Info Feb 25 13:10:49 FIREWALL event (1 of 1): modified rules
Info Feb 25 13:10:49 FIREWALL event (1 of 1): created rules
Info Feb 25 13:10:48  Feb 25 13:10:48 xDSL linestate down
Error Feb 25 12:53:36 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 125.39.31.175 [China Unicom Tianjin Asia] Dst ip: [IP Address removed] Type: Destination Unreachable Code: Communication with Destination Host is Administratively Prohibited
Looks like we may have a possible trigger & the DNS Resolver change was for the better good Smiley
Can PlusNet please review my stats to compare with this latest dropout
3CSyslog is reporting exactly the same
Just need to find out why the XDSL keeps failing ?Huh
Kelly
Fixes: 9
Yeah you just disconnected:
Kelly Dorset
TORPC
Cheers Kelly
What could be the reasons why the the XDSL keeps failing ?Huh
also wondering as I can not remember if Penfold mentioned it
Did Penfold suffer from the the XDSL keeps failing
Or
Was it something different ?Huh
Aspiring Hero
Fixes: 82
Quote from: Dandroid
Looking at your logs you had a linestate down at 15:41
Info    Feb 19 15:41:00   xDSL linestate down
Warning    Feb 19 15:41:35   PPP link down (Internet) [87.112.139.184]
Info    Feb 19 15:41:47   xDSL linestate up (ITU-T G.992.5; downstream: 9917 kbit/s, upstream: 708 kbit/s; output Power Down: 20.7 dBm, Up: 12.1 dBm; line Attenuation Down: 47.5 dB, Up: 27.1 dB; snr Margin Down: 3.1 dB, Up: 5.0 dB)
Info    Feb 19 15:41:55   PPP CHAP Receive challenge (rhost = bras-red9.cf-c)
Info    Feb 19 15:41:55   PPP CHAP Receive challenge (rhost = PTW-AG01)
Info    Feb 19 15:41:55   PPP CHAP Chap receive success : authentication ok
Warning    Feb 19 15:41:56   PPP link up (Internet)  [IP Address Removed
Info    Feb 19 15:41:56   FIREWALL event (1 of 1): deleted rules
Info    Feb 19 15:42:11   CONFIGURATION saved by TR69
You also had one on the 14th
Info    Feb 14 18:08:51   xDSL linestate down
Could this be the start of your issue and your wireless devices are not recovering from the internet connection being lost?
I did post I thought the was the cause of your issue last week.
Hopefully you have a fix now
jelv
Fixes: 10
Investigating possible problems with WiFi is rather pointless when suffering loss of sync with the exchange. Is RouterStats being run to help to try to pin down the cause of the connection issues?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
