What was the loss of service about @0:35 today ?
- Re: What was the loss of service about @0:35 today...
06-06-2013 12:54 AM
Does any one know why ,was there some planned maintenance work or a big failure?
As firstly i was kicked off the GW i was on or it went off-line, my router re connected to a different GW and a tracert was only showing plusnet's network,
Nothing was pingable outside it, for several minutes, eventually full connectivity was restored, but there seems to be an increase in hops to almost every destination was this intended?
i just checked the status page http://usertools.plus.net/status/archive/1370446687.htm that explains only part of it, although i connected to several GW's i could not access further than plusnet's network (icmp failed, as did http )
Message 1 of 7
(1,811 Views)
6 REPLIES 6
Re: What was the loss of service about @0:35 today ?
06-06-2013 10:57 AM
It seems you were disconnected due to the maintenance on the early hours of this morning.
It looks like your connection made a few attempts to connect and then disconnected again for a few minutes;
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13705122906927.png"/>
There were no issues reported, how long did it last for?
You may have been effected by maintenance too.
Message 2 of 7
(591 Views)
06-06-2013 11:46 AM
My connection got disconnected for 2 hours between 2 & 4.30am - I can see from my log it wasn't a local power failure at my house as the router wasn't power cycled.
In my case I can see for 2 hours failure to authenticate:
Jun 6 02:55:53 Router daemon.debug pppd[16529]: rcvd [CHAP Failure id=0x1 "CHAP authentication failure, unit 4629"]
Jun 6 02:55:53 Router daemon.info pppd[16529]: CHAP authentication failed: CHAP authentication failure, unit 4629
Jun 6 02:55:53 Router daemon.err pppd[16529]: CHAP authentication failed
Jun 6 02:55:53 Router daemon.debug pppd[16529]: sent [LCP TermReq id=0x2 "Failed to authenticate ourselves to peer"]
Jun 6 02:55:53 Router daemon.debug pppd[16529]: rcvd [LCP TermReq id=0x2]
Jun 6 02:55:53 Router daemon.debug pppd[16529]: sent [LCP TermAck id=0x2]
Jun 6 02:55:56 Router daemon.debug pppd[16529]: sent [LCP TermReq id=0x3 "Failed to authenticate ourselves to peer"]
Jun 6 02:55:59 Router daemon.notice pppd[16529]: Connection terminated.
Jun 6 02:55:59 Router daemon.notice pppd[16529]: Modem hangup
Jun 6 02:55:59 Router daemon.info pppd[16529]: Exit.
Message 3 of 7
(591 Views)
06-06-2013 11:58 AM
There was quite a bit of maintenance last night that would probably been the cause of this.
Message 4 of 7
(591 Views)
06-06-2013 12:10 PM
makes sense. thanks! I see the link to subscribe to service notifications on that site, will do that now.
Message 5 of 7
(591 Views)
06-06-2013 1:37 PM
Downtime was probably around 15-20 mins It was the not being able to connect to the WWW after hopping on a few GW's that caused me concern.
I'm currently on GW pcl-ag06 and the number of internal hops ,or what look like internal hops has increased
before routing to if-5-2.tcore1.W6C-Montreal.as6453.net was 14hops it's now 17 hops and to 208-64-202-68.valve.net old value was 19 hops now 21
pingbox1.thinkbroadband.com was 7hops is now 9
Target Name: pingbox1.thinkbroadband.com
IP: 80.249.99.164
Date/Time: 06/06/2013 13:10:22 to 06/06/2013 13:26:53
Hop Sent Err PL% Min Max Avg Host Name / [IP]
1 999 0 0.0 0 0 0 home.gateway.home.gateway [192.168.1.254]
2 999 0 0.0 12 395 20 lo0-central10.pcl-ag06.plus.net [195.166.128.187]
3 999 0 0.0 12 51 12 link6-central10.pcl-gw02.plus.net [84.93.249.170]
4 999 0 0.0 12 114 15 gi-1-0-1-1018.ptw-ag02.plus.net [212.159.0.178]
5 999 0 0.0 12 85 14 ae1.ptw-cr02.plus.net [195.166.129.2]
6 999 0 0.0 12 96 13 ae2.ptw-cr01.plus.net [195.166.129.4]
7 999 3 0.3 12 207 15 linx-gw1.thn.ncuk.net [195.66.224.240]
8 999 0 0.0 12 94 14 gi0-24-10-star1.core-rs2.thdo.ncuk.net [80.249.97.9]
9 999 0 0.0 12 13 12 pingbox1.thinkbroadband.com [80.249.99.164]
Target Name: if-5-2.tcore1.W6C-Montreal.as6453.net
IP: 64.86.31.6
Date/Time: 06/06/2013 13:13:30 to 06/06/2013 13:30:10
1 1000 0. 00 0 0 0 home.gateway.home.gateway [192.168.1.254]
2 1000 0 0.0 13 374 21 lo0-central10.pcl-ag06.plus.net [195.166.128.187]
3 1000 0 0.0 12 111 12 link12-central10.pcl-gw02.plus.net [84.93.249.182]
4 1000 0 0.0 12 103 14 gi-1-0-1-1018.ptw-ag02.plus.net [212.159.0.178]
5 1000 0 0.0 12 109 15 ae2.pcl-cr01.plus.net [195.166.129.6]
6 1000 0 0.0 12 119 15 xe-11-1-0.edge3.London2.Level3.net [212.187.201.209]
7 1000 0 0.0 12 79 15 ae-0-11.edge4.London2.Level3.net [4.69.200.126]
8 1000 3 0.3 12 29 12 ae-3-3.ebr1.London1.Level3.net [4.69.141.189]
9 1000 3 0.3 12 31 13 ae-56-111.csw1.London1.Level3.net [4.69.153.114]
10 1000 0 0.0 12 52 13 ae-117-3503.edge3.London1.Level3.net [4.69.166.138]
11 998 566 56.7 13 26 17 Vlan533.icore1.LDN-London.as6453.net [195.219.83.101]
12 1000 3 0.3 12 15 13 if-14-0-0-53.core4.LDN-London.as6453.net [80.231.76.74]
13 1000 3 0.3 13 59 14 if-6-1504.tcore2.L78-London.as6453.net [80.231.131.37]
14 1000 1 0.1 82 153 86 if-20-2.tcore2.NYY-NewYork.as6453.net [216.6.99.13]
15 1000 3 0.3 90 162 92 if-5-2.tcore2.MTT-Montreal.as6453.net [216.6.99.30]
16 1000 0 0.0 90 149 90 if-0-2.tcore1.MTT-Montreal.as6453.net [216.6.115.89]
17 1000 4 0.4 90 144 93 if-5-2.tcore1.W6C-Montreal.as6453.net [64.86.31.6]
Target Name: steampowered.com
IP: 208.64.202.68
Date/Time: 06/06/2013 13:15:51 to 06/06/2013 13:32:33
1 1000 0 0.0 0 0 0 home.gateway.home.gateway [192.168.1.254]
2 1000 0 0.0 13 290 21 lo0-central10.pcl-ag06.plus.net [195.166.128.187]
3 1000 0 0.0 12 83 12 link10-central10.pcl-gw02.plus.net [84.93.249.178]
4 1000 0 0.0 12 115 15 gi-1-0-1-1018.ptw-ag02.plus.net [212.159.0.178]
5 1000 0 0.0 12 95 15 ae2.pcl-cr01.plus.net [195.166.129.6]
6 1000 0 0.0 12 76 13 xe-11-2-0.edge3.London2.Level3.net [212.187.201.213]
7 1000 103 10.3 12 78 16 ae-0-11.edge4.London2.Level3.net [4.69.200.126]
8 1000 3 0.3 150 189 150 ae-3-3.ebr1.London1.Level3.net [4.69.141.189]
9 1000 0 0.0 151 171 151 vlan104.ebr2.London1.Level3.net [4.69.143.98]
10 1000 0 0.0 152 174 153 ae-41-41.ebr1.NewYork1.Level3.net [4.69.137.66]
11 1000 1 0.1 152 165 152 [4.69.201.46]
12 1000 1 0.1 153 163 153 ae-1-100.ebr2.NewYork2.Level3.net [4.69.135.254]
13 1000 1 0.1 150 164 151 ae-2-2.ebr1.Chicago1.Level3.net [4.69.132.65]
14 1000 1 0.1 151 162 152 ae-6-6.ebr1.Chicago2.Level3.net [4.69.140.190]
15 1000 0 0.0 151 172 152 ae-3-3.ebr2.Denver1.Level3.net [4.69.132.61]
16 1000 0 0.0 152 167 153 ae-2-2.ebr2.Seattle1.Level3.net [4.69.132.53]
17 999 3 0.3 152 257 155 ae-2-52.edge1.Seattle3.Level3.net [4.69.147.170]
18 999 5 0.5 152 216 154 CENTURYTEL.edge1.Seattle3.Level3.net [4.59.232.74]
19 999 4 0.4 152 221 154 [205.196.6.33]
20 999 0 0.0 152 155 152 fw01-core.tuk.valve.net [208.64.202.21]
21 999 0 0.0 153 156 153 208-64-202-68.valve.net [208.64.202.68]
Is this change down to the GW number ,the extra hops don't appear to be adding latency, or anything else unwanted, just seems a little odd
IP: 80.249.99.164
IP: 64.86.31.6
IP: 208.64.202.68
Message 6 of 7
(591 Views)
10-06-2013 5:05 PM
It can happen where you see increased hops on different gateways, you can be connected to a gateway at City lifeline and the peering is in Telehouse which could see an increase.
if you're connected to a Telehouse gateway then you're closer to the peering link.
Message 7 of 7
(591 Views)
