Weird issues with speed
gjm1976
Re: Weird issues with speed
Dunno why maybe a weird issue of bt's firmware, hes on 40/10 basic bt vdsl.
Fixes: 382
OK. Just for completeness, can you post the  BT Broadband result for your connection - as a screenshot, please - they are much easier to read than plain text extracts.
gjm1976
RealAleMadrid
Fixes: 68
@gjm1976 As has been pointed out earlier in this thread your line is banded at 25Mbps, until you get this resolved no amount of testing or looking at line stats is going to fix anything. Have you called support and asked for a DLM reset? That's the first thing you need to do. With the banding removed you should get 40 Mbps sync speed as your neighbour does. Whether your speed remains at the higher speed only time will tell, there may some problem on the line.🤔
@jab1  The Full Fibre (FTTP) Mode:On shown by the hub is a bug. It can't be FTTP if modem sync speeds are being reported.
gjm1976
I have done and finally someone got back to me, theyre requesting a DLM reset and are calling me back at 16:30 to see if all resolved.
Fixes: 382
Yup, realised that later, but was out by  that time.
gjm1976
ok reset is done, not up to 40 but a bit better.
DSL uptime:0 Days 2 Hrs 2 Mins
Data rate:7.608 Mbps / 30.761 Mbps
Maximum data rate:7.078 Mbps / 31.148 Mbps
Noise margin:5.5 / 6.2
Line attenuation:14.4 / 22.8
Signal attenuation:12.7 / 33.2
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Fixes: 480
@gjm1976
The significant factor is that SNR has been reset to 6dB. You need to leave it now, not switching the hub off or resetting it and if your line will sustain it the speed will automatically improve over the coming days.
