V slow page loading
Davegan
V slow page loading
Had plusnet for a week and it's painfully slow to load new pages.
It's fine to view HD video on utube, but takes over a minute to load a new page if it doesnt time out
Anything I can do?
23 REPLIES 23
adamwalker
Fixes: 223
Re: V slow page loading
Hi there, I've just checked over your account and can see you called in yesterday. We gave you some things to try out to resolve it, can you let me know how things went when you've been able to try that out please?
 Adam Walker
Davegan
Changed wifi channels but still slow loading new pages and links even stood information of the router
adamwalker
Fixes: 223
Thanks a lot, is it happening the same on more than one device? - Adam
 Adam Walker
Davegan
All devices in the house, Android, apple and microsoft
Fixes: 251
Are any WIRED devices showing issues?
Do you have multiple WiFi access points?
Are there any ethernet over power adapters in your configuration?
adamwalker
Fixes: 223
If possible @Davegan could you connect a device to the router with a network cable and see how the speeds compare when connected to it that way? - Adam
 Adam Walker
Davegan
Multi WiFi devices connected, only 1 WiFi router
No ethernet power adapters
Will connect laptop via ethernet and advise in a few days
Davegan
Tried lots of devices, windows laptops are OK both WiFi and connected.
Android mobiles struggle to load pages, apple mobiles are OK.
There are 3 Android phones in the house and all struggle to load pages
Assuming that the router is working correctly, I suspect that the problem is that the 2.4 and 5ghz signals use the same said, but I can't find a way to  separate them on the plusnet 2 router.
Any guidance ?
Dave
Davegan
I disabled the 2.4 and the 5ghz was slow loading pages
I then disabled the 5 and the 2.4 worked much better.
So it appears that the 5ghz wifi is the problem, we've tried this on multiple channels and I have a WiFi scanner, there is no neighbour interference.
D
Fixes: 251
On the basis of your observation that all devices other than androids work without issue, one has to suspect the android platform.
There is a legion of reports on Google of slow WiFi performance with android, many citing the fact that the phones are "slow".
Davegan
We've had the Android phones for a few years and there were no problems with them loading pages on Vodafone or on BT supplied wifi routers. So the problem is not with the phones.
I'm not happy with this level of support.
Pathetic
adamwalker
Fixes: 223
Cheers for your time on the phone just now, please see how things are when browsing over a wired connection as that will help us identify the issue and I'll call again on Monday to follow things up with you. I've documented everything we spoke about on your account here: https://www.plus.net/wizard/?p=view_question&id=234295004
 Adam Walker
adamwalker
Fixes: 223
Cheers for taking my call, as agreed I'll call next week to follow things up with you.
 Adam Walker
adamwalker
Fixes: 223
I've just tried calling to follow up with you but there was no answer. I left a quick voicemail and will give you a try again tomorrow.
 Adam Walker
