Weird issues with speed
gjm1976
Hi, i changed from a business vdsl line to personal vdsl a month or two ago (both plusnet).
I was getting 44mbit down 8.8mbit up when i was on the business line.
I have noticed things slower since being on residential line, i know my profile is only 40mbit down on personal so i know i wont hit 44mbit.
And thought nothing of it as plusnet page says im getting ;
  • Product:  Unlimited Fibre
  • Estimated Download Range:  20 - 22Mbps
  • Estimated Upload Range:  6 - 7Mbps
  • Minimum Guaranteed Speed:  18.2Mbps
  • Current Line Speed (Download):  37Mbps
However these figures are wrong....
in my hub it says ;
Connection status:
Connection type:
Fibre Broadband (VDSL)
Downstream sync speed:
24.999 Mbps
Upstream sync speed:
8.387 Mbps
So my question is why am i only getting 24mbit now on a line i was previously getting 44mbit when on business account.
Also why is plusnet control panel saying my current speed is 37 when its actually 24.99?.
22 REPLIES 22
Fixes: 387
Re: Weird issues with speed
You obviously have a fault.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
gjm1976
quiet line test is ok.
Just very weird as it happened as soon as changing from business 80mbit package to residential 40mbit package.
also very strange that the plusnet broadband page also says im conected at a higher speed.
Looks like ill submit a fault, but i thought that you shouldnt as its not actually dropped below minimum speed yet, close yes but not.
Thought maybe a snr and dlm reset might help?.
Fixes: 387
There is a fault - the 24.99 speed reported proves that. Submit a BB fault on the relevant link, but if they say there isn't one, come back for further advice.
Fixes: 479
@gjm1976
My guess would be that your line has been banded for some reason and needs a DLM reset. If you get nowhere reporting a fault then hopefully a Plusnet staffer will come along here and pick this up for you.
Fixes: 387
Would the cause of the banding not need investigation - to avoid a possible repeat?
gjm1976
I hope someone will come along , i did the text help and there was no fault found on line according to the diagnostics....
Surely the current connection speed in plusnet dashboard is bugged too?.
RealAleMadrid
Fixes: 68
@gjm1976  The Plusnet Current Line Speed is a misnomer, it is not an actual speed at all, it is a legacy Plusnet profile that has no effect for most customers but can cap your speed if you have a static WAN IP address. It is supposed to track the BT Wholesale IP profile but can get out of step sometimes. Yours is probably at the maximum for a 40/10 service but with your banded speed it is irrelevant.
Fixes: 387
In that case, we are going to have to do this the manual way.
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
gjm1976
Just rebooted router and gertting 22 down 7 up from wholesale speed test
Product code:Plusnet Hub Two
Serial number:+108417+2237002265
Firmware version:v0.08.00.08297-PN
Firmware updated:16-Mar-2023
Board version:R01
GUI version:1.9 16_08_2022
DSL uptime:0 Days 0 Hrs 3 Mins
Data rate:8.448 Mbps / 24.999 Mbps
Maximum data rate:8.448 Mbps / 29.270 Mbps
Noise margin:7.0 / 8.7
Line attenuation:14.4 / 22.8
Signal attenuation:12.7 / 33.3
VLAN id:101
Upstream error control:Off
Downstream error control:Off
gjm1976
interestingly... I asked my neighbour if i could look at his tecnical log (he has BT) and his line comes from the same pole as ours.
Firmware version:v0.38.00.10147-BT
Firmware updated:Sat Feb 25 20:48:13 2023
Board version:R01
GUI version:1.77 20_05_2022
DSL uptime:7 days,16 Hours17 Mins44 Secs
Data rate:9.052 Mbps / 39.999 Mbps
Maximum data rate:8.733 Mbps / 45.265 Mbps
Full Fibre (FTTP) Mode:On
Noise margin:6.1 / 5.3
Line attenuation:13.3 / 24.4
Signal attenuation:13.3 / 34.3
VLAN id:101
Fixes: 387
@gjm1976 Pity you rebooted before doing the check - do you remember the DSLUptime prior to the reboot?
Your D/S rate is banded, and the D/S noise margin is higher than it should be, so there is definitely an issue somewhere. Maybe avoid doing any more fiddling for 24/48 hours and then post a current version of your stats again.
Sight of the BT Broadband and BTW Performance Tester results would be a great help.
I'm out for most of the rest of the morning and early afternoon, but  if I miss anything, maybe othe Community members can comment. I'll certainly check when I get back though.
Your neighbour is on FTTP, so not a directly comparable result.
gjm1976
it was nearly 9 days uptime (we had a power cut)
And nope hes not on fttp, were quite rural and there is no fibre to houses here yet and no plans atm
according to openreach
Fixes: 387
If he's not on FTTP, why does his data say ' Full Fibre (FTTP) mode ON?'
gjm1976
Summary of Performance Test
Timestamp
Thursday 22 June 2023 | 11:7:17
Ping
12 Ms
Download
22.91 Mbps
Upload
7.91 Mbps
Advance Test
Download Test
Download speed achieved during the test was 22.91 Mbps
For your connection, the acceptable range of speeds is 16.92 - 24.17 Mbps
IP Profile for your line is 24.17 Mbps
22.91 Mbps
24.17 Mbps
Upload Test
Upload speed achieved during the test was 7.91 Mbps
IP Profile for your line is 20 Mbps
7.91 Mbps
20 Mbps
Summary Advanced Test
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you have experienced may have been caused by traffic congestion or by a server responding slowly.
Please visit the "SpeedTest Guidance" for more information.
