Web Filtering on a Thompson Router
- Re: Web Filtering on a Thompson Router
07-02-2012 4:33 PM
07-02-2012 4:43 PM
09-02-2012 5:43 PM
No I have not tried the factory re-set (do you mean the button on the back?)
But will do and re-enter sites 1 at a time.
10-02-2012 11:13 AM
Has that helped? Hoping so (and yes the factory reset is the button on the back ) - please let us know if it hasn't and we'll see if there's anything further we can do.
10-02-2012 5:57 PM
I have reset the router and there is no change. I have noticed that when I check the box (Use address base filter) the speed on my PC goes down to about 4MBS when it is not checked it is about 13MBS. I have attached the window for you to look at.
Bob
13-02-2012 10:39 AM
We've just tried replicating this but the speed doesn't change when we check the box. Have you tried it again since?
Jojo
13-02-2012 2:01 PM
Just tried it again now 13/2/12 @13:57pm unchecked Down speed 11.31 M b/s Up 0.258M b/s
Box checked Down 4.22 M b/s Up 0.156
Then straight away un-check box Down 11.59 M b/s Up 0.365 M b/s
What is the next stage?
13-02-2012 4:03 PM
15-02-2012 8:08 PM
Bob
16-02-2012 9:49 AM
Quote from: Boultons The speeds were tested on a wired connection.
Hi Bob,
I'll be honest and say that I've not seen this problem before. Just a couple of things to help us out so we can try and replicate it.
Have you tried restarting the router by powering it off and on again?
Can you confirm if you've got any rules defined for web filtering? Your screenshot seemed to indicate that there were none.
Thanks,
Matt Turner
16-02-2012 3:14 PM
Yes we have rebotted many times when we put the filter on as this was the only way of unlocking it. Yes you are correct in saying that we have nothing set from the attchment that I sent as this is the oly way the router will work without ay problems. It is a bit stange that in why have parental control on the router when they don't work, we have tried 2 routers now and both have the same problem. So it is not a problem with the router it looks like it is the softwar inside the router that is the problem. Can you get onto the people who devolped it and see what they say please. If you look back at the attchment I sent, when you check the box to filter even without entering any sites you get the problems.
Hope this helps you and you get the same results as we are having as all that plusnet team have said is for us to buy a router ourselves. This is just like putting your head in the sand and hoping it will go away!!!!!
Bob
20-02-2012 10:09 PM
21-02-2012 9:49 AM
Quote This is just like putting your head in the sand and hoping it will go away!!!!!
I'm sure you were advised that as a way of getting around the issue, we're definitely not ignoring it. Matt isn't around at the moment but I'm concerned that you've had this with two routers now. I'm going to see if I an test this one an equivalent router here.
21-02-2012 3:44 PM
21-02-2012 4:08 PM
Adam
