21CN and ADSL/2 Question
- 21CN and ADSL/2 Question
19-02-2012 5:03 PM
The question expired 14 days later as I didnt respond and had no interest in changing anything, but I thought that with 21CN you went over to ADSL2 automatically, or was that not the case in 2010?
Re: 21CN and ADSL/2 Question
19-02-2012 5:29 PM
If you're using a Plusnet supplied Thomson router, you can check what you're currently on via the following link - http://192.168.1.254/cgi/b/dsl/dt/?ce=1&be=0&l0=1&l1=0
G.992.1 = ADSL
G.992.3 = ADSL2
G.992.5 = ADSL2+
19-02-2012 7:35 PM
19-02-2012 7:41 PM
I think at that time the rule was if the expected speed was less than 4,000kbps you stayed on ADSL1
19-02-2012 7:41 PM
This page may help in accessing the stats on the hidden pages
http://www.kitz.co.uk/routers/belkin_commands.htm
19-02-2012 7:48 PM
I suspect even FTTC won't cure this as every time something has gone wrong it's been between my house and the cabinet at the end of the road
19-02-2012 8:46 PM
20-02-2012 3:53 PM
Download speedachieved during the test was - 1.93 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 5.14 Mbps
20-02-2012 4:36 PM
20-02-2012 4:48 PM
If I am not on 21CN, how come I got an email nearly 2 years ago saying I was about to be moved over!??!
20-02-2012 4:57 PM
Quote how come I got an email nearly 2 years ago saying I was about to be moved over!??!
Err... I wish I knew, sorry if it caused any confusion. Sorry, I should have said you're on 21CN but not on ADSL2, I can move you on to that if you like though.
22-02-2012 10:29 AM
I still seem to have a 2mb PlusNet profile though?
22-02-2012 11:43 AM
I have raised your profile to 7100 to allow for your new BT IP profile. This should take effect shortly. I would suggest moving to ADSL2+ though because you'll probably double your speed!
Jojo
22-02-2012 12:27 PM
22-02-2012 1:13 PM
Do you want me to move it, it'll only take a day?
Jojo
