Video stream keeps stuttering
FIXED- Subscribe to RSS Feed
- Re: Video stream keeps stuttering
12-07-2019 1:18 PM
Hi, I was previously in contact regarding being unable to play World of Warcraft without horrific ping drops. I do still have this problem and as such have given up even trying to play, the only way I could get my ping to be stable was by using a VPN, which I assume has better traffic management.
I have however noticed that my internet is struggling to stream from iplayer (not connected to VPN), I literally get 30 seconds of video then it buffers again. I have even made sure nothing else is using the internet, yet it still stutters, it makes viewing anything nigh on impossible
I would appreciate your help
Thanks,
Lexifer
Fixed! Go to the fix.
12-07-2019 1:56 PM
Hi Lexifer,
I'm sorry to hear that you're having problems with the performance of your connection, particularly when it comes to streaming from iPlayer. I've tested your line but the test hasn't picked up any problems from here and indicates that the line is currently syncing at the full 40mbps down and 10mbps up.
So that we can determine the best next steps towards a resolution for you, please can you confirm whether the iPlayer issue is solely occurring on wireless connections or if it's occurring on wired connections too? Are you experiencing any other connection problems at the moment or is it just when watching iPlayer?
Regards,
Emily
12-07-2019 7:50 PM
Hi Emily,
Thank you for the quick response. My PC is connected via Ethernet. I also have the same issue when streaming video from my friends PLEX server. I must add that this problem is intermittent however has happened frequently enough over the past few months to be annoying. Most of the time I have to refresh the page in order to continue watching. I also have issues with high ping in various multiplayer games, but due to consistent high ping I don't play them much.
Thanks,
Lexifer
13-07-2019 8:02 AM
13-07-2019 9:02 AM
Have a go on the Thinkbroadband tester. It measures single thread speeds. The lines in the results should be as close together as possible, othewise it indicates a potential issue.
Mark
13-07-2019 4:02 PM - edited 13-07-2019 4:03 PM
Hi adamwalker,
The only other devices I have are my phone and Switch, I only really watch Youtube on these and have no issues whatsoever. Literally the only things I have issue streaming from are Iplayer and Plex on my PC.
As per markfish suggestion the results for the thinkbroadband speedtest can be found here
Thanks,
Lexifer
13-07-2019 6:35 PM
Thanks for getting back to us @lexifer
Have you tried watching iPlayer on your phone to see if that has the same issue?
If your phone doesn't have issues then the issue could well lie with your PC
16-07-2019 4:09 PM
Hi MatthewWheeler,
I do not have the same issues on my phone. Thinking that it could well be my PC, like a dodgy driver or something, I have completely reinstalled Windows 10 and I still have the same issues. I also checked my ping on World of Warcraft, as I also have issues with my World ping, and it is exactly the same, it still spikes to over 500ms.
Thanks,
Lexifer
16-07-2019 4:23 PM
Hey @lexifer,
Thanks for confirming that info.
The next thing to try is plugging your connection into the test socket (if you haven't already)
This rules out your internal wiring, face plates and extension sockets as being the cause of this.
How to locate the test socket and set your connection into it can be found here.
If the problem still persists, please can you raise a fault here and let us know once this has been done?
Thanks.
16-07-2019 5:16 PM - edited 16-07-2019 5:23 PM
16-07-2019 6:17 PM
Hi @lexifer, thank you for providing the results.
Given that there's such an improvement when you're connected to the test socket, this could certainly indicate that the issue lies within the face-plate or the premises internal wiring.
It may be worth monitoring further whilst still connected to the test socket to see if the speed is consistently better. If so, the best thing to rule out as the cause first would be the face-plate as these are usually easily changed and can be picked up for a few pounds from most technology shops.
Let us know how it goes.
17-07-2019 4:11 PM
Hi LaurenB,
Quick question, is the master socket faceplate meant to be connected to anything? Because it isnt
Thanks,
Lexifer
17-07-2019 4:51 PM
With the wifi tests, have you tried splitting the 2.4ghz and 5ghz channels?
17-07-2019 6:37 PM
Hi @lexifer, although it may seem like the face-plate isn't connected to anything, when attached it actually connects into the test socket.
