Very slow getting worse
ExForce9
Re: Very slow getting worse
@stathe wrote:
Suspect noise margin 6 or 7 as on previous upsets was then lowered to 2 or 3   but unable to check as cant get into  router
@stathe
Can you describe the difficulty you are having with getting into the router ?
then someone here might be able to help and walk you through what to do.
ExForce9
@stathe wrote:
PN have not been helpful saying I have a fault in house but all checvked by Openreach here last week   They in the past haave lowered my NR to 2 or 3 But dont try very hard now  not a lot I can do have been there before so in my records   Thank you
@stathe
Your router's SNR is not something that can be set to a fixed value by Plusnet.
The SNR is determined by an automated process within the telephone exchange called "DLM" (Dynamic Line Management) that constantly monitors your line for noise interference and signal levels to determine what SNR your line is capable of.
If your line is always quiet and working well then your router's SNR number will automatically be adjusted downwards slowly (typically over ten days), whereas a noisy or faulty line will cause the SNR to go up quickly.
Openreach can reset the target SNR to an initial value (typically 6dB) for the DLM algorithm to start monitoring the noise trends on your connection, but it is then up to the DLM to adjust your router's SNR (and associated speeds) to provide the best compromise between speed, stability, and avoiding dropouts.
Even if Plusnet asked Openreach to change your line's target SNR to 3dB, while you still have a detected fault on your connection, initially your broadband would likely frequently dropout (because the SNR would be below what the line can support), then after a few days the DLM would keep raising the SNR and reducing the speed until stability was reached, but you would soon end up back where you are now with a high SNR and very low speeds.
If there is a fault with your ADSL within the house, it is unlikely that your SNR will go below 6dB until the fault is cleared.
@Leanne_T
Can you run an ADSL line check and post a screenshot of the result here, so that we can help @stathe resolve the problem,
or better still you phone him to arrange a broadband engineer investigation to help your elderly and vulnerable customer.
stathe
Needs to be sorted
Linzi_H
Hi @stathe
We've reached out to you through private message a couple of times now to help further.
If you can please get back to us with the details we've requested, that would be great.
Linzi
stathe
Unfortunately I am 90 plus and not bvery cvomputer literate would expect Plusnetn herl#   My boys who are infrequenty visitotrs haven putn meb on uswitch  smarty  with 3 for familym pads and phone   but notnhere as previously said will stay fgor phone and email with Plusnet  becausen of availabilitynnn  thank youmall   Still veryb sdlow on plusnet  line
ExForce9
@Linzi_H  I don't think you are going to get anywhere via private message,  can you just phone him ?
Linzi_H
Hi @ExForce9
We're all sorted!
Linzi
ExForce9
@Linzi_H
THANK YOU !  😍
I've spent HOURS trying to help @stathe and wasn't getting anywhere !
stathe
so what is sorted ?? still  slolw
ExForce9
@stathe
There is very little else that Plusnet can do about your broadband speed.
As I have explained several times in the topic Some advice for @stathe  you likely now have between 30 days and four months before you will lose your Plusnet telephone service, and subsequently lose your Plusnet ADSL broadband and Plusnet email.
You need to find an alternative broadband provider NOW !
  • Have you contacted Wessex Internet or Gigaclear to see whether they can connect you to full fibre ?
  • Have you asked  https://somersetcomms.co.uk/4g-5g/  to quote for fitting an outdoor 4G aerial and indoor router ?
  • Have you asked  AbilityNet  to help you, and perhaps install your 'Smarty' SIM, or improve your broadband setup ?
  • Have you checked how much Starlink would actually cost rather than just dismissing it ?
You need to get your new broadband provider up and running before you can address porting your telephone number to a VoIP phone provider, and getting your email moved somewhere other than with Plusnet (unless @Linzi_H can get you moved to Greenby ASAP ?) .
You need to understand that you won't be a Plusnet customer (for anything) in six months time.
stathe
Ohj  well Plusnet sent an independant man to check and there is a fault on the line ouytside the house to be reported to Plusnet and Openreach
stathe
They  came and saw how awfuilm but no rreal help
ExForce9
@stathe
Well that is no surprise is it ?.
I've been telling you that nothing could be done about your slow Plusnet ADSL broadband since you came home from hospital this time last year.  I've also explained why it is pointless pursuing Plusnet in the hopes of increasing the speed by a few hundred kilobits, as it will NEVER be fast enough to support a digital phone, and that your Plusnet telephone service WILL BE discontinued probably before Christmas 2026 and consequently will result in you also losing your ADSL broadband and Plusnet email. How many times do you need to be told that you need to QUICKLY change to ALTERNATIVE suppliers for broadband, phone, and email - as Plusnet won't be available to you after 31st January 2027 (or much sooner !).
I've now wasted at least five whole days of my life and many late nights researching alternative solutions for you, attempting to explain clearly what your options are, and what you need to do so that you don't lose your telephone number and email in the coming weeks.  A year later, are you any further forward ? NO !.
I give up !, I'm going to unsubscribe from all of your topics on here, I've got better things to do.  Sad
stathe
Thank you never mind my boys have put me on to  3  mobile   and retaining Plus net to be  email etc to Greenby to keep e mail  etc   Will deal with phone line later    I have  a couple of very copmpetant  sons in  the  computer and comunication   trade  But not always  at my home  to help
stathe
You seem quite cross with Plusnet  yoursellf
