Very slow WiFi speed
Smoggydan
Re: Very slow WiFi speed
I cant seem to get onto the other checker at the minute but I will keep trying and get the info over asap
Fixes: 382
OK. You don't have a desktop/laptop, then?
Smoggydan
nope its broke at the minute so ive just jumped onto the chromebook
Fixes: 382
Ah, OK .
Fixes: 382
@Smoggydan To save time and effort, do the phone test - if that fails, report a PHONE fault via: https://www.plus.net/help/report-a-problem/phone/
If it passes, report a BROADBAND problem via: https://www.plus.net/help/report-a-problem/broadband/
From the limited data you have given so far, it is obvious there is a fault somewhere, most likely within the BT/OR network, which will need investigating.
Smoggydan
Thanks very much for your help I'll get reporting
