Speed drop, and lots of disconnects
richardjh
I have been getting lots of disconnects recently, and my connection speed has almost halved, as there any ongoing issues with the service?  Its been like this for almost 2 weeks now.
23 REPLIES 23
Fixes: 305
Re: Speed drop, and lots of disconnects
@richardjh Most probably an issue with your individual connection.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
csmith94
Fixes: 31
Hi @richardjh
I've ran a quick line test and have found a fault on there that will need an engineer to come out and investigate further.
Openreach operate 2 timeslots for visits. These are AM ( 0800-1300) and PM (1300-1800), Monday to Friday
Please provide 3 timeslots you could attend and we will book the appointment for you and contact you to confirm when the engineer will be visiting.
Please note if an engineer visits your premises and is unable to gain access or if the fault is found to be caused by your equipment, your set up or your phone socket, the engineers may refer you back to us to discuss the next steps.
 Curtis Smith
richardjh
Hi, thanks for getting back to me.  I am free any afternoon, the sooner the better would be preferable.
Many thanks
csmith94
Fixes: 31
Thanks for letting me know, I've got an appointment booked in for the 08/02/23 between 1PM & 6PM. The Engineer will attempt to resolve the fault externally first before coming round, they will keep in touch on the day of the appointment.
Once the Engineer has been, our Faults Team will follow up to make sure everything is ok or if anything else needs to be done.
In the meantime, is there anything else you need from me today?
- Curtis, Plusnet Sheffield
 Curtis Smith
richardjh
That's great, thank you for your help.
csmith94
Fixes: 31
Not a problem at all Smiley
 Curtis Smith
richardjh
Hi could you possibly check my line again and see if there is another fault, I am once again having the same problems as before. Thank you.
csmith94
Fixes: 31
Hi @richardjh
I'm really sorry to hear you're seeing drops again, I've ran a line test and found the same issue on there again so I will need to get an engineer out to you.
 Curtis Smith
richardjh
Hi Thank you for getting back to me, I'm free any PM slot, apart from next Tuesday (a dreaded day of actually having to go into the office).
Thanks so much for your help
csmith94
Fixes: 31
I know that feeling all too well, I've got an appointment booked in for the 08/03/23 between 1PM & 6PM. The Engineer will attempt to resolve the fault externally first before coming round, they will keep in touch on the day of the appointment.
 Curtis Smith
richardjh
Thank you again. your help is much appreciated.
richardjh
Good evening,
Unfortunately the engineer did not turn up today for this appointment.  Can you please re-arrange?
Many thanks.
csmith94
Fixes: 31
Afternoon!
I'm really sorry the engineer hasn't come round or let you know what's going off. They found the fault external from the property and was able to issue a fix without coming to the property. How is everything now? Checking your connection it does look to have stayed stable for 24 hours.
 Curtis Smith
richardjh
Thank you for coming back to me.
Its been all good today thank you.
Thanks again for your help.
