Upstream SNRM
- Re: Upstream SNRM
Upstream SNRM
20-01-2021 11:40 PM
My upstream SNRM is going all over the place (went down to 1 dB), currently showing as ~4dB. Downstream remaining pretty constant at ~6 dB. Been an earlier disconnection, often sudden rise in errors on incoming landline phone calls.
Just the normal rubbish or anything in particular?
Any opinions?
Re: Upstream SNRM
21-01-2021 7:44 AM
@pvmb Not something I've seen very often - it's usually the D/S that plays up - but have you run a QLT/noticed noise on calls?
Re: Upstream SNRM
21-01-2021 2:48 PM - edited 21-01-2021 2:51 PM
Have you tried a different filter? Alternatively as @jab1 says do a quiet line test by ringing 17070 and selecting option 2. If there's any noise report a phone not broadband fault.
Re: Upstream SNRM
21-01-2021 10:13 PM
Large spike in upstream errors on incoming calls.
Probably just the usual - the master socket. Always the weakest link.
Re: Upstream SNRM
22-01-2021 8:16 AM
@pvmb Have you tried the QLT and change of filter suggestions?
Re: Upstream SNRM
25-01-2021 1:07 PM
Actually it could well be the exchange line card.
ADSL being dropped on incoming call is not an uncommon fault. Please run the phone line fault checker (link below).
Re: Upstream SNRM
23-02-2021 10:28 PM
Forgot about this!
In the end did the usual: 'Decoked' the connections on the Main socket/consumer plate.
Needs a regular service to keep it going. Used to this by now.
