Upstream SNRM
pvmb
Upstream SNRM
My upstream SNRM is going all over the place (went down to 1 dB), currently showing as ~4dB. Downstream remaining pretty constant at ~6 dB. Been an earlier disconnection, often sudden rise in errors on incoming landline phone calls.
Just the normal rubbish or anything in particular?
Any opinions?
6 REPLIES 6
Legend
Fixes: 265
Re: Upstream SNRM
@pvmb Not something I've seen very often - it's usually the D/S that plays up - but have you run a QLT/noticed noise on calls?
Fixes: 421
Re: Upstream SNRM
@pvmb
Have you tried a different filter? Alternatively as @jab1 says do a quiet line test by ringing 17070 and selecting option 2. If there's any noise report a phone not broadband fault.
pvmb
Re: Upstream SNRM
Large spike in upstream errors on incoming calls.
Probably just the usual - the master socket. Always the weakest link.
Legend
Fixes: 265
Re: Upstream SNRM
@pvmb Have you tried the QLT and change of filter suggestions?
Fixes: 162
Re: Upstream SNRM
Actually it could well be the exchange line card.
ADSL being dropped on incoming call is not an uncommon fault.  Please run the phone line fault checker (link below).
pvmb
Re: Upstream SNRM
Forgot about this!
In the end did the usual: 'Decoked' the connections on the Main socket/consumer plate.
Needs a regular service to keep it going. Used to this by now.
