Upload speed from 0.4 to 0.6Mb/s after cap being removed???
- Re: Upload speed from 0.4 to 0.6Mb/s after cap bei...
Re: Upload speed from 0.4 to 0.6Mb/s after cap being removed???
20-12-2013 9:45 PM
You should connect it through a filter
Quote from: rpucyk Thanks for all replys,not really sure what test socket means but I only have one phone socket in a house and router is connected directly to it, no filters used as we dont use phone land line at all, we need it strictly for broadband, please advice
20-12-2013 10:02 PM
Quote from: Oldjim You should connect it through a filter
Why ?
Filters are ONLY required when telephones and faxes (and the like) are connected at the same time.
Broadband signals work perfectly without any filter fitted when only an ADSL modem is connected to a phone line.
20-12-2013 10:48 PM
rpucyk will probably say no-one rings him, but he could be getting unsolicited calls (e.g. PPI, accident claims etc) and he wouldn't know.
20-12-2013 11:22 PM
The telephone outlet has a low pass filter which passes the audio frequencies but suppresses the higher than audio frequencies from being transferred from the handset to the phone line - which could otherwise interfere with the operation of ADSL.
Therefore no filter is required when only a modem is connected.
In fact with modern electronic designs and type approved telephones, filters are generally unnecessary anyway, because recent handsets don't emit interference outside their designed audio range.
Filters were recommended by BT about fifteen years ago because it was a simple solution for self install ADSL, for a device which cost next to nothing, would appear to work whether they were required or not, and was an easy message for consumers to understand.
I don't see why a filter would be needed to suppress anything from the incoming ringing voltage ?
21-12-2013 10:48 AM
As ejs pointed out your on a ADSL1 (G.992.1) connection, you would be better on ADSL2 (G.992.3) or ADSL2+ (G.992.5). This may automatically be corrected once fastpath is disabled.
21-12-2013 1:55 PM
Are all discrepancies you found fixable?
Can Plusnet customer service fix it?
24-12-2013 9:50 PM
Phoned Customer Service monday and been told upstream is capped (again?) and it will be sorted out in 24hrs.
No changes so far.
If CS do not see the problem you guys pointed out who can help me on this then????
24-12-2013 10:00 PM
Could you post the stats again please.
25-12-2013 11:58 AM
Quote from: jelv If the upstream bandwidth shown in the DSL connection details is greater than 448 your upload is not capped.
Thanks for your reply Jelv, it looks like upstream cap is not what causing the issue, question is why Plusnet CS still points this as a problem when is has already been uncapped 3 times.
Just done all tests and stats, you will find results below.
Also received a txt message from Plusnet today with estimated speed saying I have been with them 14 days and what should I be getting, unfortunately does not include Upload speed 😕
Download speed isn't the problem for me, upload speed is. I should be getting a double of what I'm on now.
Current upstream speed is simply not enough for a decent skype video call.
Posts from you guys suggests the problem is with phone line settings.
SInce I have not heard from Plusnet staff I will ask again:
Plusnet CAN YOU FIX IT?
25-12-2013 5:32 PM
Can you run the BT Wholesale speed test again please, but this time when the first phase finishes run the Further Diagnostic test. You will get results that look like this:
Quote Download speedachieved during the test was - 6.83 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.83 Mbps(UP-STREAM)
IP Profile for your line is - 7.15 Mbps
Note those results are from a 20CN line. As you should be on 21CN you should also results for upstream.
Your line isn't 21CN with capped upload because the sync speed is too high. I'm wondering if you have been set as ADSL1 and that 832 is the maximum upload BT use for this. You should be on ADSL2+ (as has been commented before) - I ran your phone number through the availability check which confirmed that ADSL2+ is available.
It also told me that fibre is available to you. Looking at the results it is likely that would give you actual speeds of around 70Mbps down and over 15Mbps up. Have you not considered that?
26-12-2013 9:20 AM
Big thank you to all of you guys for your help.
26-12-2013 9:36 AM
You also won't be getting twice what you are now as upstream - possibly not much more than a sync of 950kbps at best
26-12-2013 9:29 PM
26-12-2013 10:16 PM
He is however on ADSL1 21CN
26-12-2013 10:54 PM
@rpucyk Please could you run that test - the output from the diagnostic test will absolutely confirm what is going on.
