Upload router sync around 50kbps normal is 1000kbps
- Re: Upload router sync around 50kbps normal is 100...
24-07-2012 9:30 PM
Hi
The last few days the router upload syncs at approx 50kbps(normal 1000kbps). Download still has normal sync at around 4000kbps Any ideas?
Tried 3 filters and two routers tried.
Connect via Ethernet cable.
Nothing changed that I can think off.
Phone line does click now and then(10secs) when listening but pretty clear(not sure what is acceptable).
No other phone points in the house.
Window 8
DGN2000
DG834N both with current DGTeam firmware.
Any ideas?
r
Window 8
DGN2000
Any ideas?
r
Message 1 of 5
(1,253 Views)
4 REPLIES 4
Re: Upload router sync around 50kbps normal is 1000kbps
24-07-2012 11:18 PM
What happens when you connect the router directly to the test socket?
Message 2 of 5
(611 Views)
25-07-2012 7:47 AM
Hi Spencer
Thank you for the reply.
I don't have a master socket. I only have a single point socket. No other sockets/extensions etc in the house.
r
adie:Quote
r
adie:Quote
Message 3 of 5
(611 Views)
25-07-2012 11:13 AM
It's an odd one as your downstream seems to be fine. Could you post your router stats so we can see if there's perhaps a high number of errors?
I'd also advise logging this ASAP: http://faults.plus.net
Adam
Adam
Message 4 of 5
(611 Views)
25-07-2012 11:32 AM
Just to add, for information, I have had exactly the same problem on an intermittent basis.
It seems to happen when the phone rings for a long period or less frequently during a phone call and there is noise on the line (usually there isn't any)
The line resyncs during that time and although the upstream is badly affected the downstream isn't
Message 5 of 5
(611 Views)
