Unlimited fibre speed
- Re: Unlimited fibre speed
15-01-2014 10:54 AM
If it is due to the wireless signal, there are tweaks that can be done to improve it.
15-01-2014 11:02 AM
I can test the wired connection once I have finished work.
I mean dont get me wrong 18mbps is far better than the 3mbps I was getting yesterday. I am just not sure how long it takes the fiber connection to reach the optimum speed after install(which was 1pm yesterday).
Maybe I am trying to run before I can walk but according to chris from plusnet im connected at 65mb.
15-01-2014 11:09 AM
15-01-2014 11:17 AM
I didnt know if there was a better type of cable than an ethernet for this purpose.
15-01-2014 6:19 PM
Quote from: MisterW
Needs to be a wired test to get accurate results , too many factors can affect wireless speeds.
Just ran a BTW test with a wired connection
Download speed(mbps) 60.04
Upload speed(mbps) 11.65
Ping Latency(ms) 40.50
Is there any way to improve my wireless connection from
Download speed(mbps) -17.97
Upload Speed(Mbps) - 12.38
Ping Latency(ms) - 45.38
16-01-2014 9:23 AM
Ivan
16-01-2014 9:34 AM
16-01-2014 9:36 AM
16-01-2014 9:37 AM
He's with PlusNet, not BT. The speed test he posted above clearly show's he's on fibre...
16-01-2014 9:41 AM
On my laptop I get between 28 and 40Mb on wireless, the wife's laptop gets 36-42Mb and my wired connection gets 65Mb speed tests.
My older laptop on Wireless "G" would struggle to get 20Mb/s
16-01-2014 10:07 AM
Have a Nexus 7 tablet I could try it on and PS4 also which I guess I could try it on.
Are your wireless devices 803.11n capable? - Jelv
Im not that technically savvy so how would I go about checking if my devices are 803.11n capable?
16-01-2014 10:33 AM
dick:red All caps post edited as per forum rule.
16-01-2014 10:36 AM
Yes I'd say im getting fiber as where I live, you only get about 3mbps on adsl broadband.
SO with a 60mbps wired and a 18mbps wireless I would say its definalty fibre
dick:quote
16-01-2014 10:39 AM
16-01-2014 10:56 AM
First thing I'd recommend doing is checking the wireless channels where you use the wireless and then changing the channel on your router to the one least congested. You can get wireless scanning apps for most smartphones, just have a look in the relevant app store (assuming you have access to a smartphone), if not you'll likely be able to get one for a PC or Mac.
There's details on how to do that, along with some other tips, on our support pages here: http://www.plus.net/support/broadband/wireless_broadband/wireless_signal.shtml
Hope that helps.
