Now why is the router picking up the wrong DNS servers?
Routefinder
Hi All
I have noted that my Billion Router is picking up Primary 210.159.6.9 and Secondary 210.159.6.10 and not the 13.49 & 13.50 onesHuh
I can change them manually in the router settings but I wonder why the 'wrong' ones are being picked up automaticallyHuh
Re: Now why is the router picking up the wrong DNS servers?
That's a bit strange...those aren't even PN IP addresses:
dig mailgw.infomart.jp
; <<>> DiG 9.8.3-P1 <<>> mailgw.infomart.jp
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 9318
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;mailgw.infomart.jp. IN A
;; ANSWER SECTION:
mailgw.infomart.jp. 86400 IN A 210.159.6.9
;; Query time: 420 msec
;; SERVER: 192.168.1.1#53(192.168.1.1)
;; WHEN: Thu Jan 16 10:27:47 2014
;; MSG SIZE  rcvd: 52
Routefinder
oooops! typo the first set number I should typed 212 not 210 ~ doh!!!! Embarrassed Embarrassed
pwatson
The OP made a typo - First byte should be 212
Not sure he thinks they're 'wrong' though...
Fixes: 9
All four IPs point to the same load balancers and DNS servers behind them so it's nothing to worry about.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
