Unlimited Fibre Broadband Speed Massive Drop
tweedsolutions
I signed up to Plusnet Unlimited Fibre at the beginning of June this year. About 3 or 4 weeks later  I received an email from plusnet telling me that my "Minimal Guaranteed Speed" was 14.6Gb. See below...
I ran a number of speed tests and I'm now struggling to get even 4Gb
Now when I loginto my account it tells me that my "Estimated Download Speed" is only 4Gb. This is no use at all for streaming tv services.
Can someone please get in touch with me as this is complately unacceptable.
Estimated peak time speeds:
Download: 16 - 18Mb
Upload: 8 - 10Mb
These are the speeds your line is capable of at peak times.
Current line speed: 15.9Mb
This is a measure of the actual line speed you are now receiving based on the product you have taken.
Minimum Guaranteed Speed: 14.6Mb
This is the minimum speed you should expect to achieve on your line.
18 REPLIES 18
Fixes: 357
Re: Unlimited Fibre Broadband Speed Massive Drop
@tweedsolutions
It sounds very much like you have a problem - most likely not in your home/office environment, but more likely in the BT/OR network.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
adamwalker
Fixes: 223
Hi @tweedsolutions, I'm sorry about the issue with your connection speeds, I've just checked over your account and can see we've got an engineer coming out to see you tomorrow so I hope that gets it resolved for you.
 Adam Walker
tweedsolutions
It had better get fixed tomorrow as this is totally unnacceptable. My upload speed is faster than my download speed.
I've just tested it again..,
Download - 3.9Mbps
Upload - 7.1 Mbps
Ping time - 42ms
adamwalker
Fixes: 223
I'm sure we'll get it sorted for you as it's definitely not the experience we want you to have.
I'm sorry for the hassle in the meantime and do shout up if there's anything else I can help with.
 Adam Walker
tweedsolutions
So the Openreach engineer was here last Friday and claimed to have fixed the fault. It is definitely NOT fixed.
This is totally unacceptable. My broadband has disconnected 4 times already this morning and I am now gettting speeds way below what you orignially commited to me. I would like to cancel my broadband and phone line package with you. Please arrange this and I do not expect any cancellation charges.
Fixes: 357
@tweedsolutions Unfortunately, that is not how it works. If the engineers efforts failed - did he not test before he left? - then Openreach will have to return and rectify.
The chances are the problem will follow you to another ISP.
tweedsolutions
No they won't because I'm going to switch over to 4G as this is totally unusable.
Fixes: 357
OK, but you will still be subject to cancellation charges.
Fixes: 1,652
I'm really sorry to see you're having a lot of connection issues and you're wanting to leave. I'm afraid that I wouldn't at this stage be able to look at waiving cancellation charges as we'd need more of an opportunity to try to fix. If we're provided with 30 days to investigate and we can't fix then we can arrange to let you cancel without penalty.
I've tested your line and something's definitely wrong because following signing up to us, the estimated speed range of your line has been updated to between 70mbps to 80mbps. Additionally testing your line is showing the length to be only 334 metres which is backs this up as that's really short in comparison.
I would like to arrange another engineer visit with you to investigate further. If you're happy with this, when could you be available? As you may know, the engineers work weekdays (and occasionally Saturday's) 8am to 1pm or 1pm to 6pm.
tweedsolutions
Since my post this morning the broadband has gone off a further 4 times in the space of about 40 minutes. This is totally unacceptable. I work full time and cannot afford to take another day off work unpaid. Especially in these current tight financial times.
Fixes: 357
Unless you either (a) Work from home full time, or (b) are on holiday, how do you know your home connection is failing today?
Fixes: 1,652
I do understand you're experiencing a fault with your service and I'm really sorry again for this. Due to the nature of the service, things can go wrong and we need a chance to fix before we can let you leave without a cancellation fee.
Trying to think outside of the box... rather than take time off work unpaid, is it possible to take annual leave? Alternatively is there anyone else (over 18) who can be home for an engineer?
tweedsolutions
Don't try to be funny. My son is currently at home today as he has a dental appontment.
tweedsolutions
The fact that jab 1 questioned my honesty and THEN you liked his post is very offputting in a customer facing role.
