Really slow speed
Kevstar
Really slow speed
Hi.
For the last few days our download speed has been about 4 mbps. Would it be possible for someone to have a look and try and sort it out please.
Thanks in advance. kev.
9 REPLIES 9
Fixes: 380
Re: Really slow speed
@Kevstar What package (speed) are you on? Is there any noise on your phone line?
Kevstar
Hi @jab1 We are on fibre and the speed we get in around 35 mbps. A little hissing perhaps but no crackling:
Fixes: 380
As there is a slow response from Help Team staff on here, I therefore suggest you report a Broadband fault via:https://www.plus.net/help/report-a-problem/broadband/ - please report the response.
Longliner
All Star
Fixes: 8
@Kevstar  Just to be clear, does the 'hissing' occur on your quiet line test, dial 17070 from your test socket?
Mike
Fixes: 1,662
Hi Kev,
I see we've arranged an engineer visit for Thursday morning, let us know how it goes.
Kevstar
Hi @Gandalf it was working fine but has started to drop again., we should be getting just under 40 so its halved.
Fixes: 1,662
Sorry to see this Kev. I've tested your line and the tests are showing everything's spot on. Your router's in sync at a download speed of 40mbps and an upload speed of 10mbps. When you're testing your speed, is this on a device that's wired into your router using an ethernet cable or that's wireless (WiFi)?
Kevstar
Please excuse me @Gandalf it must have just been a little drop for some reason as its back to what it should be, sorry for the confusion, Kev
Fixes: 1,662
Haha no worries, panic over! Cheesy
Let me know if things break again.
