Unable to connect device to plusnet
FIXED- Subscribe to RSS Feed
- Unable to connect device to plusnet
09-03-2026 12:12 PM
My box is blue showing that its connected to the broadband. But when i try to connect my phone to the wifi, it brings me up to the Hub Manager website. When i try to leave the website it says "Use without internet". Am I doing something wrong? Do I need to do something on the Hub Manager? The wifi bars on my phone are up but there is no internet connection
Fixed! Go to the fix.
Re: Unable to connect device to plusnet
09-03-2026 12:34 PM
@Katelynj How are you trying to connect your phone?
09-03-2026 12:35 PM
09-03-2026 12:35 PM - edited 09-03-2026 12:36 PM
09-03-2026 12:38 PM
@Katelynj wrote:
I’ve also noticed in technical log of hub manager it says “setup@plusdsl.net” how do I change this? And how do I find my plusdsl net name
That explains your issue. Your PN 'name' is that you agreed with Plusnet, and, from memory, is confirmed in a 'welcome' email.
09-03-2026 12:40 PM
09-03-2026 12:46 PM
I know you didn't sign up with a 'setup' account. The easiest way to sort this is to reset the Hub by holding a paper-clip r similar in the reset hole on the rear of the hub until the light goes green (I think), then waiting until it returns to blue.
09-03-2026 12:53 PM
09-03-2026 1:00 PM
It looks like that whilst Openreach has enabled the connection, Plusnet have not yet completed setting up your account. This can take up until midnight.
09-03-2026 1:02 PM - edited 09-03-2026 1:04 PM
09-03-2026 1:03 PM
In that case, @Katelynj , I suspect @Baldrick1 is correct - post back tomorrow if you still have issues.
09-03-2026 1:04 PM
@Katelynj wrote:
I got a message 2 hours ago saying it was ready to use
Unfortunately, the PN systems are a little slow to update.
09-03-2026 1:06 PM
If the message came from Openreach, them give it time. If it came from Plusnet then ring them.
09-03-2026 1:11 PM
You could try adding your broadband username and password on your Hub navigate
->Home -->Advanced settings --->Broadband ----> Internet
make sure the hub is in the disconnected state, username is in the format youraccountname@plusdsl.net and the members centre password.
09-03-2026 1:23 PM - edited 09-03-2026 1:23 PM
