Unable to connect device to plusnet
Katelynj
I have gotten message today to say my plusnet is activated. I have set up the router to my openreach box exactly how it says in the booklet & also followed youtube tutorials.
My box is blue showing that its connected to the broadband. But when i try to connect my phone to the wifi, it brings me up to the Hub Manager website. When i try to leave the website it says "Use without internet". Am I doing something wrong? Do I need to do something on the Hub Manager? The wifi bars on my phone are up but there is no internet connection
14 REPLIES 14
Fixes: 357
Re: Unable to connect device to plusnet
@Katelynj How are you trying to connect your phone?
Katelynj
I’ve also noticed in technical log of hub manager it says “setup@plusdsl.net” how do I change this? And how do I find my plusdsl net name
Katelynj
By entering the wireless password @jab1
Fixes: 357
That explains your issue. Your PN 'name' is that you agreed with Plusnet, and, from memory, is confirmed in a 'welcome' email.
Katelynj
How do I change it? I never signed up with a setup account
Fixes: 357
I know you didn't sign up with a 'setup' account. The easiest way to sort this is to reset the Hub by holding a paper-clip r similar in the reset hole on the  rear  of the hub until the light goes green (I think), then waiting until it returns to blue.
Katelynj
I did that and it still says setup Sad
Fixes: 466
@Katelynj
It looks like that whilst Openreach has enabled the connection, Plusnet have not yet completed setting up your account. This can take up until midnight.
Katelynj
I got a message 2 hours ago saying it was ready to use @Baldrick1
Fixes: 357
In that case, @Katelynj , I suspect @Baldrick1 is correct - post back tomorrow if you still have issues.
Fixes: 357
Unfortunately, the PN systems are a little slow to update.
Fixes: 466
@Katelynj
If the message came from Openreach, them give it time. If it came from Plusnet then ring them.
Fixes: 139
@Katelynj
You could try adding your broadband username and password on your Hub navigate
->Home -->Advanced settings --->Broadband ----> Internet
make sure the hub is in the disconnected state, username is in the format youraccountname@plusdsl.net and the members centre password.
Katelynj
OMG, thank you! This fixed it 😊😊 @Dan_the_Van
