Drop in Speeds DL
DJMcKenzie87
Drop in Speeds DL
Good Morning all I hope your doing OK
I've noticed my DL Speeds hits at 12.9MBPS that's is lower yet. Can you reset my line please thank in advance DJ
As of April 24th2026, I am now utilizing Sky Broadband, which offers full support for IPv6 addressing. Broadband Status page https://stats.uptimerobot.com/i06TwWNbhx
https://gaytxtbudzuk.co.uk/ my website
4 REPLIES 4
Fixes: 353
Re: Drop in Speeds DL
@DJMcKenzie87 IF you are on 'Full Fibre' them PN can't 'reset the line - AFAIK all adjustments have to be done by OpenReach. If you are on FTTC, then you need to contact Customer Support and ask them to run checks to find the cause of your low speed.
Fixes: 463
@DJMcKenzie87
Your signature claiming Full Fibre 74 is causing confusion. Based on your previous posts you are on the basic 40/10 Fibre service, which is FTTC. If you believe that you should be on Full Fibre or want help amending your signature then please ask.
How are you testing your speed? It needs to be on a wired Ethernet connection.
Sight of your hub stats as you have posted previously would also be helpful.
Fixes: 353
@Baldrick1 Thanks for that useful information. It does help if posters give the correct details.
Fixes: 353
A question for @DJMcKenzie87 - Why are you using 4 routers - in series, or in parallel? It does not make sense.
