Two External IP adresses, is it possible?
Danmcclurg
Hi Guys,
                    Bit of an odd request here, but is it possible to have two external IP addresses, reason being i have a web server running using port 80, however i need a remote access server running on port 80 also, the only way i can think possible is via two external IP addresses? if anyone else has any suggestions then please jump in
thanks
9 REPLIES 9
bobpullen
Fixes: 316
Re: Two External IP adresses, is it possible?
Only on a business account.
Danmcclurg
Okay thank you for the reply Bob:)
pwatson
Multiple IP addresses aren't available on Residential accounts as far as I know.  Even on a business account it's debatable whether this scenario would satisfy RIPE.
Can you run your remote access application on another port, or map it to a different port with a port forwarding rule?
Danmcclurg
This is what i was hoping i was able to do, however neither application allows me to change the port as far as i can see, i may just have to invest in some different software:)
pwatson
What's the remote access server software?
BRABUS
How many IP addresses can you have on a business account?
ejs
Aspiring Hero
Fixes: 25
It's possible for a router to forward a different port to port 80, so that the remote access server would be externally accessible on some other port, but still using port 80 internally.
picbits
As ejs said - on your router configure a port i.e. 8080 on the WAN address to point to 192.168.1.x port 80 on the device on your internal network.
Then you input your IP address from a remote computer i.e. www.yoursite.co.uk:8080 to access the device.
AndyH
Quote from: BRABUS
I think the maximum is 16, but you have to have good reason for needing them.
