Two External IP adresses, is it possible?
- Re: Two External IP adresses, is it possible?
02-04-2014 10:42 PM
Bit of an odd request here, but is it possible to have two external IP addresses, reason being i have a web server running using port 80, however i need a remote access server running on port 80 also, the only way i can think possible is via two external IP addresses? if anyone else has any suggestions then please jump in
thanks
02-04-2014 10:55 PM
02-04-2014 10:56 PM
02-04-2014 10:56 PM
Can you run your remote access application on another port, or map it to a different port with a port forwarding rule?
02-04-2014 10:58 PM
02-04-2014 11:02 PM
02-04-2014 11:47 PM
03-04-2014 6:47 AM
03-04-2014 7:43 AM
Then you input your IP address from a remote computer i.e. www.yoursite.co.uk:8080 to access the device.
03-04-2014 8:15 AM
Quote from: BRABUS How many IP addresses can you have on a business account?
I think the maximum is 16, but you have to have good reason for needing them.
