Training Period Reset
- Re: Training Period Reset
12-03-2010 1:21 PM
Assuming that my long ongoing line problems have been fixed by BT, after noise & disconnections, is it better to let the download speed creep back up [present @ 120kbps with IP135] or request a reset?
Many thanks
12-03-2010 1:40 PM
If you have a high SNR due to the line problems then that could take a long time to come down on the automated system.
Mine went from SNR 15 to 6 and has been just as stable as before.
12-03-2010 2:12 PM
Assumes they confirm line stability from their data. My RouterStats shows no drop outs & a steady SRN 14, dropping to 11 in the evenings.
12-03-2010 2:20 PM
12-03-2010 2:36 PM
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
12-03-2010 2:54 PM
I wonder if any of the Comms team pick this sort of thing up from the forums?
12-03-2010 3:58 PM
Doing a 'restart & training period' was not felt necessary.
16-03-2010 11:53 AM
If you're on standard MaxDSL resetting the training period is easy, on 21CN it's near impossible.
16-03-2010 2:54 PM
Within 48hrs of BT engineer [the 3rd.] leaving, the IP shot up to 4500 and after four days all seems to be holding together! Steady SNR @ 14 & support confirms not dropping. Support advised to wait rather than go through a reset, just to see.
So, for my line, we are enjoying d'loads speeds on 4megs once again and delighted. PN support, Matt & Tony have been most helpful. Seems to me, that one requires a good bottle full of patience & perseverance [both customer & PN] with some BT lines, mine in particular.
Best wishes, Ian
17-03-2010 7:36 AM
Details below
17-03-2010 10:58 AM
I'm taking a look at this for you now.
17-03-2010 11:01 AM
17-03-2010 4:24 PM
The resynced @ 16/3 - 18.13 you mention, is not picked up on my RouterStats as far as I can see. Odd?
I see there were three drops @ about 11.00am,12.00pm,1.00pm today. Since we were out of the house on all these occasions something must have happened elsewhere!
Ho, hum - I see in the meantime the DSL has risen to 5344.
18-03-2010 7:33 AM
Now a week since the 3rd. BT visit & speeds improved [obviously not held]; quote then was, 'if this does not hold, it is the exchange & their wire to the road box'. What should be but is not working at the BT exchange?
18-03-2010 11:39 AM
Passed the fault back once more, I suspect the next step will be to arrange an engineer visit. I'll keep you posted.
