Tips on where to start - wifi dropping at around 11pm-1am every evening
RMKA
I switched to plusnet from EE in the autumn and have a problem at some point between 11pm-1am every night. The support lines are closed then and the internet is fine during the day, so I'm not sure what information I should get in order to explain the issue to PlusNet. I'm not very tech savvy, so grateful for any tips about what to look out for and what tests to run for an intermittent problem at night? Many thanks in advance.
25 REPLIES 25
Fixes: 334
Re: Tips on where to start - wifi dropping at around 11pm-1am every evening
@RMKA Welcome to the forums. Two questions before we attempt to answer your query: (1) Are you really on ADSL, or FTTC? - this will influence some of the guidance. (2) Can you explain your problem(s) in a little more detail - without something to work on it is difficult to offer advice.
TheMightyAJ
Fixes: 126
Hey @RMKA,
Just to follow up on what @jab1 has asked, is this regarding a Mobile or Home Broadband service? Smiley
 Alex H
Fixes: 459
@RMKA
The first thing to check is whether the lights are changing on your hub? If so what are they doing.
Next, is there anything being switched on or off when the failure occurs.
Fixes: 334
@TheMightyAJ / @Baldrick1  Methinks this is another time-waster . They signed out directly after apparently reading my initial reply.
Fixes: 459
@jab1
Or finished their lunchtime break and had to work?
Fixes: 334
Possible - but a quick reply would have been possible, it only takes a minute to say ' Thanks - I'll get back to you'
Fixes: 459
It does, but how often does that happen?
Fixes: 334
Very rarely, hence why I usually assume they are one-time waste of space posters, as mentioned above.
YouKnowIThatGuy
There's a lot of it about, isn't there.
Seems everyone with a slight problem wants to make it huge on here.
Mountains and molehills.
Fixes: 334
@YouKnowIThatGuy Don't quite get your point, but mine is simple: I have no issue with helping people, in fact that is why I'm still on the forum although no longer a PN customer, but ignorance gets up my nose.
YouKnowIThatGuy
If you are no longer a PN customer, you shouldn't be on the PN forums.
Even if the advice you are giving is good.
Fixes: 334
WHY????
YouKnowIThatGuy
Was that a rhetorical WHY?
Simply put: Because it's not your concern.
Fixes: 334
It was not rhetorical at all. And why is it not my concern, if anyone can can register on the forums - and they do - why cannot someone who has spent 9+ years here continue to offer support, if they so wish?
