How to connect to BT wifi
hongpeng
Hello,  I noticed that the consumer of Plusnet can connect to the BT wifi freely. Can you tell me how to make it work on my phone? Should I install some apps? Thank you.
4 REPLIES 4
Fixes: 554
Re: How to connect to BT wifi
I dont believe that PlusNet customers have access to BT Wifi
billnotben
If you are a BT customer you don't really need any app, you simply login with your BT id. When you select an open BT wifi connection a login page with come up in your browser asking if you would like to purchase any credit or login. If you select login you get a couple of options. Login wifi or if you are a BT customer login broadband (with your BT id).
As said, I doubt plusnet customers have any access to BT wifi unless they buy some credit on the web page.
adam945
Fixes: 113
Sorry @hongpeng
Plusnet customers don't have access to free BT WIFI.
 Adam
 Plusnet Help Team - Leeds
YouKnowIThatGuy
I assume you're talking about BT hotspots?
BT hotspots are dotted around large populated areas and rely on other users letting their router/connection be used adhoc for this purpose.
It's not free, indeed it's very expensive. On demand BT hotspots will cost you as much as £4.99 for one hours usage.
It's a bit like airport Wi-Fi, except with airports they'll give you 1 hour free before they ask for money.
https://www.btwifi.com/find/
Better to use your mobile data than use this.
