Tickets
- Tickets
Tickets
14-02-2011 7:38 PM
Re: Tickets
15-02-2011 1:09 PM
Re: Tickets
15-02-2011 1:52 PM
Those have been picked up for you now. With regard to the profile reset, I've actioned this one for you but it's not really something that we can keep doing every few months.
Re: Tickets
15-02-2011 4:58 PM
Re: Tickets
15-02-2011 8:16 PM
More alarmingly, there are currently 37 people on hold on the phones, and the longest wait time was 32 mins (now 24 mins). Not that I'm having a go (there might be staff illnesses or something), but this is certainly the longest turn around time I've had.
Re: Tickets
15-02-2011 8:37 PM
Matt, yes, resetting my SNR every few months is not good enough, but I'm not willing to pay £20 a month for a service that holds a steady 2.5 to 3mb connection to then suddenly drops to a 1mb or sub 1mb. Next time it happens I will raise a line fault.
Re: Tickets
16-02-2011 4:44 PM
I don't know the whole issue, but it sounds a bit like the issues I was having. PN put me onto a trial to remove me from the DLM, thus essentially "fixing" the SNR on my line. Essentially sacrificing stability for speed. However this doesn't seem to be happening now (hence my ticket) but you might want to look into it.
Re: Tickets
16-02-2011 5:14 PM
I didn't realise you were having this issue. I'll have a look into it now for you.
Jojo
Re: Tickets
16-02-2011 5:36 PM
Even though we have fixed your target to 6dB it doesn't mean it will stay at that. What it means is that it will try each time it connect to establish it at 6dB but depending on the state of the line at the time it may set itself at a different SNR. I've just ran a check and at the moment it is actually showing as 4dB.
Jojo
Re: Tickets
16-02-2011 8:30 PM
Hi Jojo, would fixing the snr margin help my at all? Is it also possible to action my ticket no. 39907238.
Thanks,
Dave
Re: Tickets
18-02-2011 1:13 PM
Re: Tickets
18-02-2011 1:50 PM
The option to fix the SNR is not currently available to us on 20cn technology. I have actioned your ticket request for you.
Jojo
Re: Tickets
18-02-2011 3:12 PM
My broadband has become unusable for periods of time again today and I've had enough. I will be searching (on my friend's reliable broadband) for an alternative provider
Re: Tickets
18-02-2011 8:08 PM
Re: Tickets
19-02-2011 12:31 AM
